Hey. I am a long term Roon user. For years, I have used an iPhone and iPad mini as remotes. I have been trying to use my iPad Pro as a remote as well, but it will not connect. I have tried all of Roon’s suggestions and have even redownloaded the app but with no success.
Any ideas? Any assistance will be greatly appreciated. Thanks.
wizardofoz
(Mr Fix It aka The Wiz)
March 22, 2020, 4:31pm
2
are you sure you are not on your guest network or that your WiFi and lan are on the address range…
Perhaps start a #support thread
Yes. And, same wireless network and settings as with iPhone and iPad mini that fo connect.
#support
wizardofoz
March 22, 2020, 6:21pm
4
I’ve moved this to support area…and flagged @support but up it’s a weekend so sit tight till they get to you
You might like to give more details about your network setup so they can see what could be up
RBM
(René)
March 22, 2020, 6:53pm
6
Let’s keep things in one place. Since the original support thread has a bit more info, let’s continue there:
TEXT GOES HERE
Soon Core runs on Sonore Sonictansporter NUC server. Cisco wireless router. Players are wired. iPhone and iPad Mini work fine as remotes.
Network D…
I’ll close this one.
