I am having the exact same problem - My iPad running 10.17 will not upgrade to 2.0. The little circle off to the right just spins and spins
Hi @Timothy_Webb ,
You can manually install the 2.0 on your iPad from the App store:
This is just on the iPad, correct? The rest of your Roon Remotes work fine?
Also, please complete the below template so that we can understand your setup better, thanks!
Include your operating system and machine info (Model, CPU, RAM)
Your network gear (model of routers/switches) and if on WiFi/Ethernet
Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.)
Tell us how large your music library is, eg. “30,000 tracks”
Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated!
