iPhone Air not appearing as Roon audio zone despite other iPhones working (ref#8MJSTH)
· A connected audio device is not appearing in Roon
Is your RoonServer machine running MacOS 15 Sequoia or above?
· I still can't see my endpoints as available Zones.
· WiFi
· RoonReady
· No, it does not show up there
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
· I have a *mesh network* with devices connected to multiples points
Your local network might need some re-arranging to support Roon.
· None of the suggestions have helped me. I'd like to submit a support request.
· This is an ongoing, persistent issue, not a one-time playback failure tied to a specific track. The iPhone Air has never appeared as a Roon audio zone, so no track was playing on the Air as a Roon zone. Last confirmed occurrence: 2026-10-27 at 20:17 CST (Asia/Shanghai, UTC+8). At that time the Air's Roon app logs were captured after a fresh reinstall: the Air's RAAT server was running and listening on port 9200, but the Core sent it zero requests (no enumerate_devices, no enable_device, no refresh) and the Air never appeared as a zone. Also confirmed the same day at 20:09 CST, immediately after reinstalling the Roon app on the Air: the fresh app connected to the Core as a Remote but still did not appear as an audio zone. Controlled comparison the same day at 19:50 CST, with all iPhones on Tailscale and Roon at once: the Air did not appear as a zone while the SE 3 and XS did and played.
· Affected device: Apple iPhone Air, iOS 26.2.1, built-in output. Connection type: Wi-Fi to the home router, then Tailscale (WireGuard mesh VPN) to the remote Roon Server; audio protocol RAAT (RAAT 1.1.48, latest Roon app). The phone's RAAT server runs and listens on port 9200, but the Core never enumerates or enables it, so it never appears as a zone. Working comparison devices on the identical setup and connection: Apple iPhone SE 3, iOS 26.6.1, and Apple iPhone XS, iOS 18.7.4, both also on RAAT 1.1.48 and the latest Roon app.
iPhone Air never appears as a Roon audio zone, while other iPhones on the same setup work normally.
Setup: Roon Server 2.74 (build 1712) on a remote Linux VPS. The iPhones are on a single home Wi-Fi router for internet access and reach the Core over Tailscale, a WireGuard-based mesh VPN (tailnet). This is a remote Core over VPN, not a same-router LAN, not a home Wi-Fi mesh, and there is no managed switch. (In the earlier network question I selected 'mesh network' only because Tailscale itself is a mesh VPN.) The affected zone would be the iPhone Air's built-in output, via RAAT over WiFi/Tailscale. I selected 'RoonReady' in the protocol question as the closest RAAT option; this is not AirPlay, Chromecast, or another protocol.
Pattern: iPhone Air (iOS 26.2.1) never appears as an audio zone, in Settings > Audio or anywhere else. iPhone SE 3 (iOS 26.6.1) and iPhone XS (iOS 18.7.4) work normally on the same setup and stream via the Core. All phones run the latest Roon app and RAAT 1.1.48. Local Network permission is ON and identical on all phones. The Air plays audio from other sources normally; its iOS audio session activates and deactivates normally and volume/route changes register. The problem is specific to Roon.
Log findings: The Air's RAAT server runs and listens on port 9200, but the Core never sends it any request - no enumerate_devices, enable_device, or refresh - and it never exposes an audio output. By contrast, the SE 3's RAAT server receives those requests and streams via coreaudio_ios. Both phones identify as localhost internally. The 'drop send to unspecified 0.0.0.0' lines appear in the logs on both phones and are not the cause.
Firewall: Roon ports TCP 9330/9331/9332, 9150, 55000 and UDP 9003 were verified reachable from outside the public IP, and all Remotes connect to the Core successfully. No formal iptables/ufw rules audit was performed. iOS has no user-configurable firewall.
Troubleshooting already tried: reinstalled the Roon app on the iPhone Air on 2026-10-27 (it connects as a Remote but still never appears as a zone); force-quit and reopened Roon on the Air multiple times; checked Local Network permission and app/RAAT versions on all phones. Not yet tried: restarting Roon Server, restarting the iPhone Air, restarting the router, or toggling Tailscale off/on.
Roon Server runs on a remote Linux VPS, not on the local network: VMISS, Los Angeles, plan US.LA.TRI.Pro, 1 vCPU (AMD EPYC), 3 GB RAM, 20 GB disk, 300 Mbps port, Debian 11. The iPhones are on a single home Wi-Fi router for internet access (one access point, not a Wi-Fi mesh; phones get addresses in the 192.168.68.x range) and reach the Roon Server over Tailscale, a WireGuard-based mesh VPN (tailnet). There is no managed switch and no signal extender known. The home Wi-Fi router brand and model are not known, and the modem/ONT brand and model are not known. The 'mesh' in the earlier network question refers only to the Tailscale mesh VPN to the remote VPS, not to the home Wi-Fi.
Mobile devices can be set to a private mode which means they can’t be seen/controlled by other remotes. Is it that simple or am I on the wrong track?
Hi Henry, thanks for checking. I don’t think it’s that — the Air doesn’t appear as a zone on the Air itself either. In the Air’s own Roon app, Settings > Audio shows only the SE 3 and XS; the Air’s own zone never appears. If Private Zone were on, the Air would still see its own zone.
From the Roon app logs (Air vs SE 3): the Core connects to the SE 3’s RAAT server over Tailscale and the SE 3 exposes its audio output, but the Core never connects to the Air’s RAAT server at all. The Air’s RAAT server is running and listening on port 9200, but it never exposes an audio output. All four phones have identical Roon iOS settings and the latest app version.
So the Air’s endpoint seems to never register with the Core. Happy to share logs or try anything you suggest.
Hi @XIN_GUO,
For Roon and device discovery to work properly, all devices have to be on the same flat local network and subnet. Remote configurations like this are unfortunately beyond the scope of official support, and we can’t assist here directly.
The simplest solution would be to migrate your server to be on-site in your current location, or to authorize a second server and deauthorize the one at home.
If you’d like to proceed with the remote WAN setup, we’ll move this to Tinkering for other users to weigh in.
OK, cool. Well above my level of understanding! :joy:
Hi Connor, thanks for the clarification. The remote setup is intentional — the server runs on a VPS and the phones connect over Tailscale — so moving the server on-site isn’t what I’m looking for right now. Could you please move this thread to Tinkering so other users can weigh in? One detail for anyone reading: Private Zone is ruled out — the iPhone Air doesn’t see its own zone either, and the logs show the Core never connects to the Air’s RAAT server at all, while the SE 3 works over the same Tailscale path. If anyone has seen a RAAT server fail to expose its audio output on an iPhone Air specifically, I’d appreciate hearing about it. Thanks, XIN_GUO
Hi @XIN_GUO,
Thank you for the clear write-up. As Connor mentioned, a Roon Server reached over a VPN from another location is outside what we can support, so we’re moving this thread to the Tinkering category, where other users who run similar setups can share their experience. We won’t be following up on it from the support side, but the details you’ve posted should help anyone who has seen this before.
