Hi Frank - I just wanted to generally join the conversation. Any idea how I can delete and (maybe) repost? Thanks. Too bad about Beekhuyzen. Perhaps I’ll edit before re-posting. Gene
No worries
No need to edit on my account. Just repost. You made some excellent points.
Purity is a meaningless term. No recording method is perfect, no mixing method is perfect, no two recording studios or performance environments are the same, no playback system is perfect, no two listening rooms or listening positions are the same, no two ears are the same (indeed your own ears vary with health and degrade with time, while your sense of pitch and timbre can be improved by training), and of course the way that sound is rendered into your conscious brain involves all sorts of subtle psychological trickery.
Setting aside the above, the notion of perfect playback is rendered meaningless by the fact that it is impossible to reproduce the dynamics of live classical music through any recorded medium (and would in any event both deafen you and alienate any neighbours you might have), while most pop music relies on electronic amplification (both for the singer and instruments) and often plenty of studio special effects to achieve the final mix so is inherently ‘distorted’.
The ONLY thing that matters is that the sound you hear when playing back recorded music through whatever medium and system you choose sounds ‘right’ to you. In my case that means produces a sound that is engaging and approximates to a relatively convincing impression of SOME live performances (large orchestral in full swing is always going to be an impossibility I would suggest).
As a analogy think of all those dull holiday snaps that failed to live up to your memories of delightful sunlit landscapes / vibrant townscapes and larger than life incidents. A great deal of Photoshopping is often needed to get anywhere near matching the sensations you actually experienced when there. Perceptions are NOT reality.
This is why most Quad amps (aimed fairly and squarely at a classical listening audience) have always had balance controls and filters. The fad for removing them remains just that, a fad. There is no justifiable reason to do so other than to removed poor quality components. But the idea that an amplifier without tone controls is inherently superior to one without them is, in either the pre- or post-analogue worlds, is I believe deeply flawed.
I’ve had many home stereo systems over the 40 plus years that I’ve been able to assemble my own; my current one is certainly not inexpensive (although by no means in the esoteric range). And I’ve listened to a wide range of music (although these days it is restricted mainly to 20th/21st century classical) a fair amount of it live. But replaying digital downloads (or music transferred from LPs or CDs) via a NAS, Roon Rendu and DAC, and taking full advantage of DSP (different settings for pop and classical and for headphone / preamp combinations or speakers) in a quiet and comfortable home environment gives me by far the most enjoyable rendition of recorded music that I can recall. And without doubt studio standard FLAC downloads offer me the best quality and tonal / timbral reproduction at present. But unfortunately many of the best performances on record are, as yet, unavailable in that medium and I also need DVD for the video component of ballets and operas.
You know lossless makes sense, right?
Hi,
Excuse my ignorance, where is these Lossless signal path & Enhanced Signal Path that appears you are able to change it ?
Thank you !
Great Thanks !
