When I am away from home I would like to bring a laptop that now has Roon remote installed. I was wondering if it was possible to make it the core only for those days I’m away from home and then go back to using it as a remote when I get home. I wouldn’t bring the PC that now has the core because it doesn’t have the programs I need when I’m away.
Your account allows one core, if your laptop has a library on it you can deactivate your normal core and activate the lap top then reverse the process once you get home.
You will need to have local files and build a local library on the lap top. Currently you cannot remote access your library
