Show DSP preset in “signal path” as a single named entry.
I have created several named DSP presets with similar processing steps in them. It is not possible to differentiate between them by expanding the “signal path” graphic. This can be fixed by either just showing the preset name in the “signal path”, or showing the preset name in a collapsed expander panel which, if expanded, would show the full set of processing steps.
