Issue with library on hard drive Versus Qobuz streaming
Core Machine
PC Core i5
WRITE HERE
Network Details
WiFi 5 GHz connection
WRITE HERE
Audio devices : 2xDevialet Phantom Classic
WRITE HERE
Library Size
Hard drive on PC around 100 Go
WRITE HERE
I have around 100 Go of MP3 quality songs in my library on my Roon Core PC.
I have a Qobuz account, which is linked to my Roon.
When I want to listen to a song via Roon - Qobuz in High Definition via streaming that I already have in my hard drive library in MP3, if I type the reference of the song in the Roon research, I find the file referred to with two icons: My library and Qobuz at bottom of the album cover. But the issue is that Roon always plays the song in MP3 quality that I own in my hard drive library, but I would like to listen to it in HD quality via Qobuz. Not possible. I’m sure there is a setting which would allow me to bypass the song stored in my Hard drive, and play it in High Definition through Qobuz streaming. But I did not find such setting in Roon. Can you help me?
WRITE HERE
Hi @Noam_Pinard
You should be able to select the version you’d like by going to the Versions tab when you visit the album. Here you can also set the default “Primary” version of the album so it defaults to Qobuz instead of local for that specific album.
Roon “should” pick the best quality versions. If it’s not then that’s not something you should have to fiddle with - it’s a bug.
