· I'm hearing clicks, pops, or unexpected noises
Is there a specific error message you see? If so, please select from the following options:
Please try to reboot your Roon Server and check to see if this helps.
· Rebooting my Server had no effect, the issue remains
Please try to reboot and unplug/replug in your affected audio device and check to see if this helps.
· Rebooting and unplugging/replugging my audio device, the issue remains
Please open your Roon Remote and select the "System Output" Zone and try to play to it. Do you encounter any playback errors with this Zone?
· I can play back music *without issue to System Output*, it is only the *other zone that has issues*
What method is the audio device connected with to the server (Roon Ready, HDMI, USB, AirPlay, Chromecast, etc.)?
· HDMI
Is the audio device on the latest firmware version, as per the manufacturer's app?
· Yes
Is there any change in behavior when using a different cable for the connection for the audio device?
· No, using a different cable didn't change anything
Have you reached out to the manufacturer of the audio device regarding this issue yet?
· No, I have not reached out
· Both local and streaming content are affected
Please try playing content of a lower sample rate (44.1kHz or 48kHz). Do you still have the same issue?
· No, lower sample rates are still affected
What is the model/manufacturer of the affected audio device(s) and the connection type?
· Marantz SR6015, HDMI
Hello, I am new to Roon. I have a NUC ROCK connected via HDMI to a Marantz SR6015 receiver. The NUK is connected via ethernet cat-6 cable to my fiber modem.
ROCK setup went smoothly. I was able to update the BIOS and codecs. The machine is a Roon-recommended: Intel NUC11PAHi7 with 16gb ram and 512gb ssd. My local library is on an external hdd connected to ROCK by USB.
After first booting the NUC ROCK, music plays normally through the Marantz receiver, and sounds great! When I turn off the receiver and turn it back on, the music is slow and very distorted. The only remedy I have found is to reboot the NUC each time I want to listen to music. Restarting Roon Server s/w doesn't help.
Troubleshooting I've done so far:
- Tried playing local and Tidal streaming files
- Tested multichannel dsf, stereo dsf, flac, wav, mqa and mp3 files
- Tried different bit rates and sample rates under Device setup
-Tested connecting to several hdmi inputs on the Marantz, and tried different new cables (hdmi & ethernet)
- Tried enabling 'Headroom management' and/or 'Sample rate conversion' in MUSE
- Tried mapping the Marantz to several Roon-tested Marantz devices in Device setup under 'Identify this device'
- Unplugged and re-plugged everything back in
- Rebooted the modem, players, receiver, PCs and tv
- I made sure all devices have the latest firmware and software updates
- I set up a second NUC as a Roon Bridge running Windows 11 pro, connected via HDMI to the receiver, and wi-fi to Roon ROCK. I tested a few generic ASIO drivers on the Bridge (ASIO4ALL, FlexASIO, Steinberg). Occasionally I'd get silent playback instead of the slow distorted audio.
The NUC ROCK and Bridge are connected to separate power sources from the rest of the equipment.
I'm able to play Roon music through Chromecast to my Sony TV, on to the Marantz receiver in stereo. Playing from Roon to an Oppo BDP-105 USB dac, to the Marantz also works fine, but only in stereo because the Oppo 105 dac is 2-channel only. I would like to be able to enjoy my collection of multichannel dsf albums (ripped from SACDs using Oppo 105)
The Marantz plays fine with all other hdmi and analog sources.
Thank you for reading! Any advice would be much appreciated. Happy to post screenshots and send log files as needed.
CenturyLink C4000XG gigabit fiber modem, TP Link wifi mesh extenders (not for ROCK which is on ethernet). All devices are on the same gateway & subnet. Permanent DHCP reservations
