Hello folks. I’ve got a PI 4 w 4gb and I was planning on creating a room endpoint with it for my usb dac. I followed instructions flashing as card with Ropiee and then putting it into my Pi4. I had connected Ethernet cable to the Pi and had the as card installed. I powered it on and it said it had flashed Ropie to it and it saw network connection etc. after doing such I connected my dac via usb to it amd this is where issue runs. I don’t see the endpoint in a room. Also how do I enable WiFi using Ropieee. I feel like I’m doing something wrong here.
Ok so I can see it now only if Ethernet cable is attached. How do I enable WiFi. I did not see anywhere after it booted up where I could do such. As soon as unplug Ethernet it’s not seen.
Also, check your roon-core firewall. Make sure the firewall is disabled or you open all necessary ports. In case you need the list of needed ports, they are:
TCP/IP Ports 9100-9200
TCP/IP Port 52667
TCP/IP Port 52709
TCP/IP Ports 63098-63100
TCP/IP Port 49863
I actually got these ports from this forum. Somebody had a connection issue that turned out to be firewall-related and posted the port list, so I have the list saved in my notes in case I need them.
