Have you restarted everything after upgrading ?
I did restart everything.
The only reference I could see to scrolling in the B778 Release Notes was under Focus, which reads:
- Scroll position doesnât persist between pages
This seems the opposite of what you are wanting. Iâll see if we can attract a dev to explain what the intended behaviour is here.
That is the name of the bug. Its listed under fixed.
I canât reproduce this on Windows. Stays fixed even between restarts of the Remote and the Core.
Update: Still an issue.
Note: Different remote devices may need to be fixed individually.
Do you use bookmarks?
Yes. (10 chars)
There must be something wrong with your setup! In my copy the âscroll positionâ works perfectly OK.
So I fired up my macbook pro which I use as a remote and surprise, its not fixed on it either. The scroll issue is still present. Even though I updated and restarted the laptop. You can blame it on one machine, but two? CommonâŚ
Not unless you have selected the Discography tab under an artist. The overview tab works fine but the Discography scrolls to the top when hitting the back button. This scroll issue is pure madness! Iâm so â â â â â â I have no words!
Ok, I see. Then it was fixed ONLY in the Albums section. And doesnât work in the Recent activity and Discography.
Even in the albums section, if you apply some filters or simply use bookmarks that go to the albums section (and applying filters and sorting) it still scrolls to the top. I understand that this doesnât happen for anyone and I canât tell why its happening for me (on 2 different machines with different configurations). @support please get my logs and fix this because Iâm going crazy here.
I have exactly the same issue - super annoying. I have thousands of albums in any given genre, I scroll through them, getting to âpâ for example, go back to previous page, and it scrolls to the top!
Please Roon fix this. It is a major annoyance!
So Iâm not alone in this. Thanks for letting me know. I donât understand whats going on at Roon. 4 weeks ago they were aware of this issue. Others as well as myself have detailed the issue and they acknowledged it and yet no fix. Furthermore they say they did. How is this not seen as critical is beyond me.
Iâve checked it. Yes, the same for me. If I apply several filters, it goes up to the top every time. So, this bug wasnât fixed.
I created a separate request in support. Roon need to know about this issue and they need to know how many users its affecting. I agree with you: itâs rendering the Roon experience redundant right now.
Like so many things. So much for extended beta testing and QA.
Scrolling issue for sure not fixed. Never had issues in albums view even before 778, but absolutely had and still have this issue in bookmarks and when expanding the recent activity on the home view.
