Hi,
I have downloaded this album in surround sound as a wav file. I can play by VLC and other players but not import in Roon. The file is simply ignored.
Any idea how to import this file in Roon?
What is its resolution? I have 5.1 FLACS and it has even imported and recognised a DTS CD I own (though it can’t play it to a normal DAC).
It should be 5.1
Does it show in Skipped Files?
Hi, yes it is! With the reason „audio stream format not supported“. I remember a review about this album, where the author mentioned a 5.2 mix, although on the download website (by Jean Michel Jarre himself) it was named a 5.1 format. Could that be the reason and can I convert to 5.1?
Hi @Thomas_Martin, hard to say for sure. Is it a .wav file? If so can you send it to me in a PM so I can take a look on my side? Thanks!
Sorry, this 5.2 thing was a mistake. I converted the 24 bit 48 kHz 5.1 wav file with the very recommendable AuI ConverteR 48x44 in a 24 Bit 48 kHz 5.1 Flac file and now it works perfectly! Thank you a lot
