Speaker and Mac connected via Ethernet Cable to Fritz Box 4040
KEF LS50 Wirless
Hello, I am aware that there are several posts with a similar topic, but it seems nobody has my exact problem:
I am listening via Tidal and upsampling to 192/24 and using a parametric eq in DSP. LS50 W and Macmini are connected via cable on the router, software of KEFs is p6.2101809171.105039
Upsampling works reliably in this constellation. But when I skip a song and listen to the next one 2 out of 3 times playback stops after 2 seconds for several seconds (as if it was buffering!) afterwards it plays the song without interruption. It works when I listen to a complete album, no interruptions.
Anybody else got this problem? I have a fast internet connection, so I don’t suppose it is waiting for the tidal files to load. I listen to few flacs on my harddisc, but so far it seems the problem only occurs when streaming via Tidal.
LS50 can only playback 192 via USB interface, if your using a Ethernet connection then 96 is your highest rate, even if you up sample, 96 is the highest. I think.
Not true @Shawn_Costello. I own LS50w and play to them all the time at 192/24 via wireless Ethernet. (They also handle 192/24 via wired Ethernet and USB).
Only the Optical input is restricted to 96/24 maximum.
Actually… looking at their literature… they do state that USB is max 192/24, and Optical Toslink is 96/24 as I mentioned… but… they don’t actually state a spec for Ethernet/Dual Wireless 2.4 GHz/5GHz Wi-Fi.
However… as I’m sure you’ve noticed… Roon’s signal path shows that it delivers 192/24 to them when you play to them via Ethernet (wired or wireless). So it’s my understanding that that’s what they receive.
Thank you for your report here. We are aware of a few similar reports regarding this behavior and have reached out to KEF regarding this. In the meantime, I would verify that your LS50s are on the newest firmware available.
