Intel NUC ( NUC5i5MYHE)
R.O.C.K.
Version 1.6 (build 416) stable
Gigabit internet connection, Google Wi-Fi (router), R.O.C.K. connection = wired, KEF LS50 connection = wired, Cat 5e cables
KF LS50 Wireless via ethernet
When DSD files are played, there’s no sound. Standard and high resolution PCM play well but I’ve tried this with numerous albums and I’m wondering if I need to change some settings so the LS50 will play these albums?
If you try to play these DSD files to another endpoint or to the ROCK’s HDMI output (connected to a TV), do you still experience this behavior? Have you tried multiple DSD files or just the Prince of Darkness one listed in your screenshot? You can grab a few other DSD sample files from the 2L Test Bench if you only have that current one to test.
Thanks for confirming with the other DSD files. I requested that our hardware team attempt to reproduce this behavior with the LS50s we have in the lab and they have been unable to do so, DSD64 down-sampled is playing as expected.
I have a few other thoughts here:
Can you verify to make sure you’re using the newest firmware on your LS50s?
Is the behavior the same if you set your Max Sample Rate (PCM) to 96kHz?
