With the original Kef LS50 Wireless, it’s easy to measure the room/loudspeakers, because there’s usb connection available. With the new LS50 W II there is no longer a usb connection. Is there another way to use REW?
REW has the possibility to save the measurement sweep(s) as a file. You can add it as an ordinary music file and play it. Should work the same as USB measurement.
I like the convenience of playing a file.
But a USB to TOSlink or USB to digital coax will work fine.
miniDSP USBStreamer B is great.
