KEF LS60 Wireless & LSX II not playing DSD/DXD anymore following April 2026 firmware updates
Following the recent firmware updates v3.0 for the KEF LS60 Wireless and LSX II (both Roon Ready), which - successfully - brought the long awaited Qobuz Connect, unfortunately both speakers won‘t play hi-res DSD and DXD files anymore. As if the v3.0 puts too much strain on their internal processors. In the case of the LS60 W DSD64 still plays, but 2x or 4x DSD won‘t. Neither does DXD 352.8kHz. And with the LSX it‘s even worse: no DSD accepted anymore. I am referring to Roon streams via RAAT and wired Ethernet. I’ve already tried re-boot, switch off, and factory reset, without success, though. Obviously there are workarounds (sample rate conversion within Roon), but it‘s still a hardware feature which is „broken“ by the latest firmware. I opened support tickets with KEF, but am curious to know, whether other fellow Roon users experience the same (or similar). This phenomenon is not the same, but maybe connected to the sample rate/format switch issue discussed by @James_GALT and @alex_h.
AFAIK, the LS60 never played >DSD64.
Were you having Roon downsample those before but not now?
Besides, the LS60 downsamples everything to 24/96 (wireless) or 24/192 (wired) anyway.
Although the maximum resolution is not specifically mentioned on the spec sheet (it only states „DSD“), up until firmware 2.6, both the KEF LS60 Wireless as well as the LSX II accepted DSD256. This shows in numerous reviews published following the launch, it is also the standard/default ceiling for DSD when you activate within Roon. And I can tell from experience that my speakers accepted untampered DSD256 streams - until last weeks‘ updates. The fact that, inside the speaker, everything is converted to PCM192 (or 96 for wireless connection to secondary speaker) for KEF’s MIE processing is a different story.
Although I run a Nucleus Titan, converting DSD256 natively to PCM192 is too demanding for the Roon server (at least with the filter settings I prefer, it can only convert at 0.4x speed which is obviously not sufficient) so I chose to stream DSD256 directly to the KEFs. Following the firmware update, this is not possible anymore, and in order to stream DSD256 to the KEFs, I have to either select a less demanding filter settings in MUSE or switch off native DSD conversion within MUSE. These are all workable work-arounds, but they don‘t change the fact that firmware 3.0 is a regression to 2.6 in this respect.
I’m only rarely using the KEF LSX II for background music, but here I let in every case Roon resampling to max 24/96 (also with interconnect cable, it’s the internal max).
Why are you want to use native dsd processing before resampling? If you’re using some DSPs in the DSD area and after them a converting to PCM, you’ll have only a need for a lot of horse power (which your system doesn’t has) but not a better sound.
Also the speaker itself has in every case DSPs activated and works here in the PCM domain.
Let‘s please stay on topic. I have started this thread in order to learn whether there are fellow Roon users who can replicate/confirm the issue at hand. I did not mean to start a discussion about whether or not DSD is a useful format (esp. > DSD64) or where DSP conversion should take place (in the server or in the speaker) and how it should be done - and, most importantly, whether or not this makes an audible difference.
Understood.
Please don’t misunderstand me (I’m using in a lot of cases DSD also with HQPlayer, but not with the KEF).
I wanted only say, that in your case native DSD resampling doesn’t make a sense…
If you want further send DSD to the KEFs, then you’ve IMHO ask KEF for a solution (they have also changed something in the Roon integration).
In my original post I mentioned I opened support tickets with KEF. On this forum, I just want to share my observations following the firmware update and understand whether other members have experienced the same. I am aware that from the Roon angle, the issue cannot be solved.
I plan on purchasing some LS60s and despite not having an interest in DSD, I am commenting to follow along as I am keen to know how this pans out.
Best of luck with KEF :+1:t2:
I reported it to them the day it was released, and I immediately noticed the same problem posted above. I told them it had to do with their release and they did not seem to think that it did but they took my information but have never gotten back to me. I’ve gotten around it by using Roon to do the processing for these files…no issues with DSD files on the Kef’s until that April software update.
Doug
I will post again should I hear back from KEF. My experiences with KEF support in the past were rather irresponsive to negative. For instance, in spring 2024 they introduced Google Cast 2.0 to their speakers (v2.2, May 2024) which effectively reduced all Qobuz App streams (no Qobuz Connect in 2024) to 44.1/16 from previously max. 96/24. I reported this to KEF support, they iterated a few times and asked for numerous screenshots proving the speed of my network connection and the hi-res nature of my Qobuz titles etc., only then to never come back with any response. They were just assuming user error, as usual. Interestingly, the v3.0 firmware (which I complain about in this thread) finally brought workable Google Cast at 96/24 again - almost 2 years after they introduced the problem with their faulty Chromecast implementation. Another example: the introduction of Qobuz Connect has also taken 10 months on the existing LS speaker range. Much longer than with most audio brands. In the meantime, the only response received from KEF support was always “KEF software team is working on it - you can use the KEF Connect App if you want to play Qobuz”. So this is about what you can expect from KEF support in terms of responsiveness and problem solving.
In response to your first question, yes, I am experiencing the smae problem Playing DSD through the KEF LSXII.
Likewise here with KEF LS60s
I’m having the same issue with my KEF LS50 Wireless II. After the recent update DSD will no longer play at all. If I try to resample to the most compatible PCM rate I get random pops and click, sounds like I’m playing vinyl.
Updated to latest noticing Roon and Roon ARC both failed to play my local .dsf DSD files.
Roon showed “Audio device refused to switch input to Roon” (my audio device is KEF LS60) when trying to play DSD files. But FLAC files are playing ok.
Switched to KEF Connect native app and the same sets of DSD files on NAS are playing normally.
@Vincent_Lam I moved your post to a thread covering this topic. If this is not correct, I can move it back or you can create a separate Support request thread.
Same here KEF LS50 Wireless II.
DSD 64 tracks play fine. 128 or above crack/pop.
Mmh, in Roon I limiting the sources to 24/96, but over DLNA I can play also DSD256 without problems on the LSXII with firmware 3.0.135.
Surely my KEFs are connected with LAN and interconnection cable.
Replying to keep topic open. This is still an ongoing issue. I have a huge ripped SACD collection that now will not play on my KEF LS50 Wireless II, which is one of the primary reason I subscribe to Roon vs streaming alone. I can’t send any form of DSF files 64, 128, or 256 via Roon, DLNA works fine. When I try to use the sample conversion to resample DSF to PCM, no matter what frequency I choose there is distortion in the form of clicks and pops. Can anyone from Roon support comment?
Tech Support don’t monitor this forum category. I see that it has been reported in Support and this is an issue for KEF to resolve. Roon Labs are aware and will be in communication with KEF as necessary.
