Ok, starting now !
Yes, @Adam_Dabrowski you found an important clue. For me the same. KEF wireless connected to the router on startup: no volume issue. KEF wired connected to the router on startup: volume issue (100 %). @mike @Eric
Wow, for @Adam_Dabrowski â I reproduced once I was connected over ethernet. Previously I was connected over WiFi.
Thanks guys â weâll open up a ticket on this one and let you know what we find.
nice! thanks!!!
Just a data point.
I just tried this sequence with my android Pixel c and do not see this issue.
I have the same problem. Iâm using a ROCK server with my main PC as a remote. My KEF LS50Wâs are ethernet input. When I start ROON and then turn on my KEFâs, the volume control shows 100%. But they are not at 100%, they are only displaying 100%, but play at my previous setting, of say, 30%. If I use the KEF volume control and click down the volume once, the display goes to my previous setting. Same thing for the Roon volume control. Last week I updated ROON and KEF on the same evening and this is when it started.
just updated Roon 1.3 276 and it works fine :)!
thank you!
I take it back. It doesnât work again. Still 100% on the startup
Not sure if it helps, but I am using the KEFs sometimes with a Synology DiskStation over DLNA and it happens there too. (Though I am using WiFI)
So I guess it is rather an issue with the speakers than with roon.
Interesting, glad Iâve seen this post.
Due to the Naim (Control) App being flaky, Iâve been trying to use Roon (on a Sonictransporter i7) to serve to my Naim Uniti 2 streamer. But Iâve not got it reliably working yet - and on the rare occasion I get sound, the Uniti 2 volume is maxed out at 100. The Uniti 2 is set for a âwiredâ network connection.
I look forward to seeing whatâs concluded / how I avoid almost blowing the drive units in my speakers again! Cheers.
I unintentionally managed to reproduce this a few days ago and was playing music with young family in the roomâŠ
Luckily I noticed right away and the track started off quietly so no harm done.
Bit concerning as I imagine these speakers at instantaneous full cranking would be really unpleasant
Any status updates and/or planning for this issue?
We think we have a fix, and I need to test it. If itâs good, it will be in the next release.
on the side noteâŠ
would be great to be able to set volume limit (option).
Recently my finger slipped and volume ended up on 80. Oh my, oh my, that wasnât pleasant at all!
Itâs a good idea⊠and thatâs all Iâm saying about that
Well, it appears the fix may not have come soon enough for me. Another inadvertent UPnP bridge blast at full volume seems to have left a lasting âhissâ (proportional with volume) emanating from the Uniti 2. No other source/amplifier available here to check if itâs a problem with my PMC speakers or the Uniti 2. Great. Juuuuuuuust great.
oh lord!!!
Anyone know when the fix for this issue is being released?
Thanks in advance.
