KEF Wireless 1 audio devices keep disabling (ref#YLJ32E)
· audio devices keep disabering. Kef wireless 1
· Devices keep disabering. Including Kefs wirless ones
Hello @Ronald_Scott, welcome to the community!
Thank you for reaching out. To help investigate this, could you please share a bit more detail:
  1. What device is your Roon Server running on?
  2. Are the KEF Wireless 1 speakers connected via WiFi or Ethernet?
  3. When the devices disappear, do they come back on their own or do you need to do something to get them back?
  4. Could you note the exact time of the next occurrence so we can check the logs?
1 Running on windows 11 desktop
Disappears randomly when Roon app is turned off
On the correct WiFi
Hi @Ronald_Scott,
We’ve identified a few events in Roon Server diagnostic logs for your account that correspond to what you’re describing.
Device updates from this endpoint stopped reaching RoonServer shortly after playback concludes, and the KEF’s UPnP timers expired. This caused the endpoint to tear down as an active Zone, and then disappear from Roon entirely.
Basically, the network pathway between the KEF and Roon is no longer carrying data, either because that data is never being sent by the KEF or because that data is lost in transit.
I’d first verify that the KEF isn’t going into standby mode, and I’d try connecting it to the main router for testing instead of a WiFi access node, if relevant. Try hardwiring the device via ethernet.
I also recommend double-checking that multicast forwarding is enabled in your network settings for your router.
Additionally, the Microsoft Defender firewall will sometimes sever Roon’s ability to discover local network endpoints. Ensure that RAATServer.exe and RoonServer.exe are both added to the safelist.
Let us know if this helps.
Hi @Ronald_Scott,
Just checking in on this, have you had a chance to try the steps we mentioned, like checking whether the KEF is going into standby, testing it on the main router or via ethernet, and confirming multicast forwarding is enabled? We also asked you to make sure RAATServer.exe and RoonServer.exe are allowed through Microsoft Defender, since that can block local device discovery. If you’ve made any progress or found anything new, let us know, thank you!
