CXN v2 passes the PCM signal just through to the digital outputs. What point are you trying to make?
Seems easy enough to test. Just try uncompressed FLAC versus WAV to see if the compression is the culprit.
FLAC will uncompress to PCM which will be 100% the same as before the compression. If you believe it is not so you can start new thread âVoodoo in sound engineeringâ or the like.
Let us close the thread as it goes nowhere. I have found the way to contact Support directly so thank you all but I will wait for them to respond
Hi @plex_plex,
I see that you have also reached out via our email channel, I will go ahead and close this thread per your request and continue the conversation via email.
