ROCK running on 7i7BNH, works great! When connected to Lampizator Level 4 /R2R DAC via USB out (back or front), from the Zone section of Roon client, I can not see the DAC. Same DAC worked with Windows PC well. I remember I installed drivers from Lampizator yaers back on my PC. Do you know if there is any chance, if such drivers can be supported for ROCK, or am I going in a wrong direction? @support
Thank you in advance.
Could you take a screenshot of the Settings > Audio screen with the Lampizator Level 4 plugged into the NUC running ROCK from your remote? I’m curious to see if the DAC isn’t being discovered at all or if it’s having issues communicating with the Linux audio drivers.
