The level control is locked, and I can’t fix it!
I presume you are in the middle of writing something that will make sense?
I assume you mean the volume control is set to fixed?
You will need to go to settings:audio: device setup to change to device volume from fixed.
If that’s not what you meant a little more information would help… a lot…
