Linear power supply for ST i7
The specs say 19v 5a. Does a LPS for the i7 have to meet this? Will it run as well with lesser voltage and/or amperage?
It should work on 12v at 5a and also 19v at 4a.
We over spec it a little bit because its a bad idea to run your supply at 100%.
If you need a good linear supply we sell one.
This includes all the cables you need. This unit has 4 outputs so you can power other devices with it as well. Works great with our microRendu and also most small network switches.
