Currently the core is on my 2015 MacBook Pro (Dual-core i5 with 8GB memory; OS=Catalina v.10.15.6). This is also currently being used as the output device to my Cambridge Audio CXA80 amplifier through a Toslink connection directly from my MacBook Pro (last model to have this capability). This is the computer that I currently use for all my computing needs. (Not ideal)
I intend to switch my core to a separate dedicated computer on network, hard-wired through CAT-7 ethernet cable. The computer with the Roon core will probably be based on an AMD RYZEN 3 3200G 4-Core 3.6 GHz which combines CPU and GPU.
My current setup (MacBook pro) and future plans (AMD will both involve the core being connected to the network through ethernet cables. The main router is a Bell Home Hub 3000.
My main amplifier (Cambridge Audio CXA80) does not have an ethernet port. This is the key focus of my query. While I could use a ChromeCast audio device that I currently own, I prefer to have a direct ethernet connection - e.g. through some streaming device.
I am seeking your advice on how “best” to connect my Cambridge Audio CXA80 to the network.
Considerations:
(1) I like the idea of using a Raspberry Pi-based device, as this offers greater control over software revisions and flexibility. One possibility is simply connecting to my amp’s DAC through S/PDIF, using something like the ALLO DigiOne Signature or equivalent from HiFiBerry. Advantages: (a) control over software revisions; (b) relatively inexpensive; © the ALLO DigiOne Signature is getting reviews indicating superior performance over many high-end audio streamers – including the BlueSound Node 2i; (d) There is much greater flexibility down the road with going the Raspberry-Pi route.
(2) Alternatively, I am considering the BlueSound Node 2i. Advantage is that it is also MQA-enabled, so it would be able to do the second-stage rendering of MQA-encoded recordings. Disadvantages: (a) no control over software upgrades or if manufacturer chooses to no longer support the device; (b) relatively more costly.
My questions:
Should MQA even be a consideration? I have seen only a few Tidal recordings with MQA encoding and several of these are “only” at 96 khz, so the Roon rendering is all that I would get. Is there really any audio difference with the second (hardware) rendering?
If MQA does make a difference, are you aware of any Raspberry Pi-based streaming devices (DACs?) that are MQA enabled?
If I were to emphasize audio quality generally for FLAC recordings (most of Tidal’s inventory), my choice would be a high-quality Raspberry-Pi based SPDIF connection. If MQA hardware rendering were to be an important consideration, then I would consider purchasing an MQA-compliant device to connect to my amplifier.
I should add that I do sense a difference in audio quality between the FLAC 44.1khz/16bit and the 96khz/24bit recordings side-by-side. That being said, I am quite happy with the audio quality with my current setup, where my core and output device are both the same computer with a direct Toslink connection with the Cambridge Audio CXA 80. While I am willing to upgrade devices and connections, I am looking for value for the investment.
Thanks for your help with this.
Don
