NUC8i5BEH with 16GB RAM, running ROCK, with latest - 831 - version of Roon
ISP provided router and Netgear GS 108 switch
Linn Klimax DS/3, connected by ethernet and running latest firmware
67k tracks approx.
I liked the idea of lock screen controls but having played around I’ve found one thing that’s an issue for me.
I use a remote with a Linn KDS (Roon Tested) to quickly raise, lower or mute the volume as it’s quicker than grabbing the iPhone or iPad. Previously to 831 if I adjusted the volume using the remote, the apps would reflect that change. They no longer do. My startup volume is set at 30. Whatever I do with the remote the apps display 30. If I use the physical volume controls on the Apple devices to change volume, the apps reflect the change, but unless the volume was still at 30 when I started, the volume displayed is out of sync with the actual volume.
E.g. I start playing music, but using the remote push the volume to around 45. If I go into the app (still displaying 30) and use the side buttons to increase the volume again, the app will display 31, 32, 33 etc., but the actual level shown on the KDS will show 46, 47, 48…
Michael
Editing to add: If Roon Remote isn’t running, and I mute the volume using the Linn remote, when I next run Roon Remote it brings the system out of mute straight away, which is not something I wish to happen.
