Exactly the same with me…! ROCK Core, Linn Sneaky. Worked perfectly before ca. 3 weeks.
Other endpoints/players work perfectly fine.
Hi @misig1,
I have split your post into it’s own thread so I can better assist you here.
Can I please ask you to reproduce this issue once more, note the exact local time + date in your country when it occurs (e.g. 7:39PM on 6/14/19) and then manually send me the logs from your Core by using these instructions?
Also if you can provide the following additional info it will be useful in troubleshooting this behavior:
– Noris
Hi Noris
sorry for the delay…
it was the firmware…, as simple as that.
sorry, I didn‘t check before. Without frequently opening linn‘s „konfig“ (service software), one doesn‘t realize that a new firmware was ready… (but that‘s of course not your issue).
Thanks anyway!
Hi @misig1,
Thanks for the update here, and glad to hear that installing the newer firmware solved the issue!
