There’s a problem with LIve radio. Jb radio always cut. And for radio paradise, is it possible to obtain sound artist and titles.
Don’t use the FLAC streams if you want the track info. From https://radioparadise.com/listen/stream-links:
FLAC Links
Main Mix FLAC (http://stream.radioparadise.com/flac )
Mellow Mix FLAC (http://stream.radioparadise.com/mellow-flac)
Rock Mix FLAC (http://stream.radioparadise.com/rock-flac )
Eclectic Mix FLAC (http://stream.radioparadise.com/eclectic-flac )These links currently do not currently include stream metadata (song title info). Not our choice. We would if we could.
This is nothing new and applies to FLAC streams from other stations too AFAIK.
I assume you mean JB Radio-2. Yes, a couple of streams are now showing unobtainable. I have replaced with a working stream.
Thank you for pointing this out.
