Synology DS1819+ running DSM 7.0-41890, Roon Core 2.0 (build 1154) running on Docker
Unifi Dream Machine Pro, UWS-24-POE switch, fully wired network
IKEA Symfonisk using Sonos protocol
45,000 tracks
Our 4-month old baby is having teething issues and the only thing that will calm her down is playing the same song over and over again (“The Happy Song” by Imogen Heap - if you know, you know). However, when using the ‘loop’ button in Roon on our Symfonisk, it will play once, play a second time and then stop. I’ve checked and it’s there is definitely no 1
showing on the loop button so it should loop indefinitely, I think.
What’s extra weird is that it gets stuck on 00:00:00 and I can’t then just click “Play” again in Roon. I actually have to go into the library and select the song again, then click “Play” to get it to restart.
Things I’ve tried
- Restarting Roon Core, networking gear, Symfonisk – same thing
- Using Airplay to the same device, rather than the Sonos protocol – same thing (see last log)
- Rather than clicking the ‘loop’ button, just adding the same track to the queue multiple times – this does work but then the playlist eventually runs out
I’ve grabbed some logs from a couple of times that it’s happened:
11/22 22:10:10 Trace: [Master bedroom] [Lossless 8.2x, 16/44 FLAC => 16/44] [62% buf] [PLAYING @ 2:27/2:37] The Happy Song - Imogen Heap
11/22 22:10:10 Trace: [Master bedroom] [zoneplayer/sonos] request matches stream, current path: /cd7a76397ec349d4a46e606dc722b2f5/Roon1d197cff7a5943c2910e807474f8bbf7.flac, next path: /b1c4998973864d7ca3d72ab0ec060071/Roon9.flac
11/22 22:10:10 Trace: [Master bedroom] [zoneplayer/sonos] reached end of stream, closing connection
11/22 22:10:10 Trace: [Master bedroom] [zoneplayer/sonos] transaction canceled, isplaying: True, did stream end: True, tx path: /b1c4998973864d7ca3d72ab0ec060071/Roon9.flac, stream path: /cd7a76397ec349d4a46e606dc722b2f5/Roon1d197cff7a5943c2910e807474f8bbf7.flac, method: Get
11/22 22:10:15 Trace: [Master bedroom] [Lossless 8.2x, 16/44 FLAC => 16/44] [62% buf] [PLAYING @ 2:31/2:37] The Happy Song - Imogen Heap
11/22 22:10:20 Trace: [Master bedroom] [Lossless 8.2x, 16/44 FLAC => 16/44] [62% buf] [PLAYING @ 2:37/2:37] The Happy Song - Imogen Heap
11/22 22:10:20 Info: [stats] 25050mb Virtual, 3270mb Physical, 1402mb Managed, 636 Handles, 106 Threads
11/22 22:10:21 Trace: [Master bedroom] [zoneplayer/sonos] position timer, stream ended naturally, path: /cd7a76397ec349d4a46e606dc722b2f5/Roon1d197cff7a5943c2910e807474f8bbf7.flac
11/22 22:10:21 Trace: [Master bedroom] [zoneplayer/sonos] State transition Playing => Disconnected
11/22 22:10:21 Trace: [endpoint/sonos/uuid:RINCON_347E5CF0CBF601400] check zone coordinator, device coordinator: RINCON_347E5CF0CBF601400, roon coordinator: RINCON_347E5CF0CBF601400
11/22 22:10:21 Trace: [client/sonos] timers stopped
11/22 22:10:21 Info: [audio/env] [zoneplayer] All streams were disposed
11/22 22:10:21 Debug: Lastfm '97BBea9wxOkvQcXv78tVAPc8JlQj6HfG' DONE: Imogen Heap - The Happy Song
--[ SignalPath ]---------------------------------------------
SignalPath Quality = Inactive
Elements:
11/22 22:10:21 Warn: inactive signal path :(
11/22 22:10:21 Info: [library] recorded play for profile 8d27f530-fac9-4916-8292-0169ae46049e: mediaid=50:1:c953e58b-5779-4979-af10-2c9e75913b2a metadataid=97:0:184811021571825 contentid= libraryid=50:1:c953e58b-5779-4979-af10-2c9e75913b2a isfromradio=False isfrommix=False isfrommobile=
11/22 22:10:21 Info: [zone Master bedroom] OnPlayFeedback OnToNext
11/22 22:10:21 Debug: [zone Master bedroom] _Advance (Track)
11/22 22:10:21 Trace: [library] finished with 2 dirty tracks 2 dirty albums 3 dirty performers 2 dirty works 1 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 0 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 8 changed objects
11/22 22:10:21 Info: [library/albumdetails] found 1 ingroup alternates, 0 other alternates
11/22 22:10:21 Debug: [easyhttp] [43888] POST to http://ws.audioscrobbler.com/2.0/ returned after 148 ms, status code: 200
11/22 22:10:21 Trace: [client/sonos] av_status
11/22 22:10:21 Trace: [Master bedroom] [zoneplayer/sonos] state from device: PLAYING
11/22 22:10:21 Trace: [Master bedroom] [zoneplayer/sonos] zoneplayer state: Disconnected
11/22 22:10:21 Trace: [Master bedroom] [zoneplayer/sonos] state from device: STOPPED
11/22 22:10:22 Debug: [music/profilestats] Computed stats in 372ms, got 50 top albums, 50 top performers, 18 genres
11/22 22:10:22 Debug: [music/profilestats] Computed stats in 358ms, got 50 top albums, 50 top performers, 18 genres
11/22 22:10:22 Trace: [dbperf] flush 0 bytes, 0 ops in 12 ms (cumulative 47912824 bytes, 32051 ops in 134083 ms)
11/22 22:10:22 Trace: [library] endmutation in 1237ms
11/22 22:10:22 Trace: [music/searchindex] [search-index] removed: 1 albums, 1 tracks, 0 works, 1 performers, 0 labels, 0 genres
11/22 22:10:22 Trace: [music/searchindex] [search-index] added in 373541ms: 1 albums, 1 tracks, 0 works, 1 performers, 0 labels, 0 genres
11/22 22:10:23 Debug: [easyhttp] [43891] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 457 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43894] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 469 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43896] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 469 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43892] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 472 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43895] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 555 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43893] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 687 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43890] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 688 ms, status code: 200
11/22 22:10:23 Debug: [easyhttp] [43889] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 717 ms, status code: 200
11/22 22:10:31 Trace: [Master bedroom] [Lossless 8.2x, 16/44 FLAC => 16/44] [62% buf] [PLAYING @ 0:00/2:37] The Happy Song - Imogen Heap
11/22 22:10:35 Info: [stats] 25074mb Virtual, 3294mb Physical, 1527mb Managed, 635 Handles, 109 Threads
11/22 22:10:37 Trace: [Master bedroom] [Lossless 8.2x, 16/44 FLAC => 16/44] [62% buf] [PLAYING @ 0:00/2:37] The Happy Song - Imogen Heap
11/22 22:10:43 Trace: [Master bedroom] [Lossless 8.2x, 16/44 FLAC => 16/44] [62% buf] [PLAYING @ 0:00/2:37] The Happy Song - Imogen Heap
11/23 19:35:01 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 1:56/2:37] The Happy Song - Imogen Heap
11/23 19:35:06 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:01/2:37] The Happy Song - Imogen Heap
11/23 19:35:08 Info: [stats] 23813mb Virtual, 3111mb Physical, 1134mb Managed, 487 Handles, 91 Threads
11/23 19:35:12 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:07/2:37] The Happy Song - Imogen Heap
11/23 19:35:18 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:13/2:37] The Happy Song - Imogen Heap
11/23 19:35:23 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:18/2:37] The Happy Song - Imogen Heap
11/23 19:35:23 Info: [stats] 23813mb Virtual, 3096mb Physical, 1112mb Managed, 487 Handles, 94 Threads
11/23 19:35:29 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:24/2:37] The Happy Song - Imogen Heap
11/23 19:35:32 Trace: [Master bedroom] [zoneplayer/sonos] request matches stream, current path: /bd8bba2646ba493385a45a5696609197/Roona62cdbf488db44c2b9df21523e9d2224.flac, next path: /3d818c11d44e4ac2a89240c40027bbaa/Roon0.flac
11/23 19:35:32 Trace: [Master bedroom] [zoneplayer/sonos] reached end of stream, closing connection
11/23 19:35:32 Trace: [Master bedroom] [zoneplayer/sonos] transaction canceled, isplaying: True, did stream end: True, tx path: /3d818c11d44e4ac2a89240c40027bbaa/Roon0.flac, stream path: /bd8bba2646ba493385a45a5696609197/Roona62cdbf488db44c2b9df21523e9d2224.flac, method: Get
11/23 19:35:34 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:28/2:37] The Happy Song - Imogen Heap
11/23 19:35:38 Info: [stats] 23821mb Virtual, 3041mb Physical, 1092mb Managed, 487 Handles, 93 Threads
11/23 19:35:40 Trace: [Master bedroom] [Lossless 5.4x, 16/44 FLAC => 16/44] [8% buf] [PLAYING @ 2:35/2:37] The Happy Song - Imogen Heap
11/23 19:35:43 Trace: [Master bedroom] [zoneplayer/sonos] position timer, stream ended naturally, path: /bd8bba2646ba493385a45a5696609197/Roona62cdbf488db44c2b9df21523e9d2224.flac
11/23 19:35:43 Trace: [Master bedroom] [zoneplayer/sonos] State transition Playing => Disconnected
11/23 19:35:43 Info: [audio/env] [zoneplayer] All streams were disposed
11/23 19:35:43 Trace: [endpoint/sonos/uuid:RINCON_347E5CF0CBF601400] check zone coordinator, device coordinator: RINCON_347E5CF0CBF601400, roon coordinator: RINCON_347E5CF0CBF601400
11/23 19:35:43 Trace: [client/sonos] timers stopped
11/23 19:35:43 Info: [library] recorded play for profile 8d27f530-fac9-4916-8292-0169ae46049e: mediaid=50:1:c953e58b-5779-4979-af10-2c9e75913b2a metadataid=97:0:184811021571825 contentid= libraryid=50:1:c953e58b-5779-4979-af10-2c9e75913b2a isfromradio=False isfrommix=False isfrommobile=
Elements:
11/23 19:35:43 Warn: inactive signal path :(
11/23 19:35:43 Trace: [library] finished with 2 dirty tracks 2 dirty albums 3 dirty performers 2 dirty works 1 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 0 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 8 changed objects
11/23 19:35:43 Info: [zone Master bedroom] OnPlayFeedback OnToNext
11/23 19:35:43 Debug: [zone Master bedroom] _Advance (Track)
11/23 19:35:43 Trace: [client/sonos] av_status
11/23 19:35:43 Trace: [Master bedroom] [zoneplayer/sonos] state from device: PLAYING
11/23 19:35:43 Trace: [Master bedroom] [zoneplayer/sonos] zoneplayer state: Disconnected
11/23 19:35:43 Debug: Lastfm '97BBea9wxOkvQcXv78tVAPc8JlQj6HfG' DONE: Imogen Heap - The Happy Song
11/23 19:35:43 Info: [library/albumdetails] found 1 ingroup alternates, 0 other alternates
11/23 19:35:43 Trace: [Master bedroom] [zoneplayer/sonos] state from device: STOPPED
11/23 19:35:43 Trace: [dbperf] flush 0 bytes, 0 ops in 1 ms (cumulative 3962294 bytes, 1866 ops in 53636 ms)
11/23 19:35:43 Trace: [library] endmutation in 131ms
11/23 19:35:43 Debug: [easyhttp] [149] POST to http://ws.audioscrobbler.com/2.0/ returned after 142 ms, status code: 200
11/23 19:35:43 Trace: [music/searchindex] [search-index] removed: 1 albums, 1 tracks, 0 works, 1 performers, 0 labels, 0 genres
11/23 19:35:43 Trace: [music/searchindex] [search-index] added in 20243ms: 1 albums, 1 tracks, 0 works, 1 performers, 0 labels, 0 genres
11/23 19:35:44 Debug: [easyhttp] [150] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 422 ms, status code: 200
11/23 19:35:44 Debug: [easyhttp] [151] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 437 ms, status code: 200
11/23 19:35:44 Debug: [easyhttp] [153] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 665 ms, status code: 200
11/23 19:35:44 Debug: [easyhttp] [152] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 666 ms, status code: 200
11/23 19:35:45 Trace: [broker/accounts] [heartbeat] now=11/23/2022 19:35:45 nextauthrefresh=11/23/2022 20:25:53 nextmachineallocate=11/23/2022 23:25:45
and, finally, a log from when it happened using Airplay
11/23 19:58:12 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:04/2:37] The Happy Song - Imogen Heap
11/23 19:58:17 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:09/2:37] The Happy Song - Imogen Heap
11/23 19:58:23 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:15/2:37] The Happy Song - Imogen Heap
11/23 19:58:24 Info: [stats] 23840mb Virtual, 2402mb Physical, 789mb Managed, 492 Handles, 97 Threads
11/23 19:58:29 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:21/2:37] The Happy Song - Imogen Heap
11/23 19:58:34 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:26/2:37] The Happy Song - Imogen Heap
11/23 19:58:35 Trace: [Master bedroom] [zoneplayer/sonos] request matches stream, current path: /4e4a09d3757a4a69905ac51324e77a80/Roon86b53785339a49178228daf410bd39da.flac, next path: /e0940480201649b3a51da7d0c82ebe75/Roon0.flac
11/23 19:58:35 Trace: [Master bedroom] [zoneplayer/sonos] reached end of stream, closing connection
11/23 19:58:35 Trace: [Master bedroom] [zoneplayer/sonos] transaction canceled, isplaying: True, did stream end: True, tx path: /e0940480201649b3a51da7d0c82ebe75/Roon0.flac, stream path: /4e4a09d3757a4a69905ac51324e77a80/Roon86b53785339a49178228daf410bd39da.flac, method: Get
11/23 19:58:39 Info: [stats] 23832mb Virtual, 2402mb Physical, 785mb Managed, 499 Handles, 93 Threads
11/23 19:58:40 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:32/2:37] The Happy Song - Imogen Heap
11/23 19:58:45 Trace: [Master bedroom] [Lossless 8.1x, 16/44 FLAC => 16/44] [84% buf] [PLAYING @ 2:37/2:37] The Happy Song - Imogen Heap
11/23 19:58:46 Trace: [Master bedroom] [zoneplayer/sonos] position timer, stream ended naturally, path: /4e4a09d3757a4a69905ac51324e77a80/Roon86b53785339a49178228daf410bd39da.flac
11/23 19:58:46 Info: [audio/env] [zoneplayer] All streams were disposed
11/23 19:58:46 Trace: [Master bedroom] [zoneplayer/sonos] State transition Playing => Disconnected
11/23 19:58:46 Trace: [endpoint/sonos/uuid:RINCON_347E5CF0CBF601400] check zone coordinator, device coordinator: RINCON_347E5CF0CBF601400, roon coordinator: RINCON_347E5CF0CBF601400
11/23 19:58:46 Trace: [client/sonos] timers stopped
11/23 19:58:46 Debug: Lastfm '97BBea9wxOkvQcXv78tVAPc8JlQj6HfG' DONE: Imogen Heap - The Happy Song
11/23 19:58:46 Info: [library] recorded play for profile 8d27f530-fac9-4916-8292-0169ae46049e: mediaid=50:1:c953e58b-5779-4979-af10-2c9e75913b2a metadataid=97:0:184811021571825 contentid= libraryid=50:1:c953e58b-5779-4979-af10-2c9e75913b2a isfromradio=False isfrommix=False isfrommobile=
11/23 19:58:46 Trace: [library] finished with 2 dirty tracks 2 dirty albums 3 dirty performers 2 dirty works 1 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 0 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 8 changed objects
Elements:
11/23 19:58:46 Warn: inactive signal path :(
11/23 19:58:46 Info: [zone Master bedroom] OnPlayFeedback OnToNext
11/23 19:58:46 Debug: [zone Master bedroom] _Advance (Track)
11/23 19:58:46 Info: [library/albumdetails] found 1 ingroup alternates, 0 other alternates
11/23 19:58:46 Trace: [dbperf] flush 0 bytes, 0 ops in 1 ms (cumulative 3962294 bytes, 1866 ops in 53638 ms)
11/23 19:58:46 Trace: [library] endmutation in 87ms
11/23 19:58:46 Debug: [easyhttp] [168] POST to http://ws.audioscrobbler.com/2.0/ returned after 294 ms, status code: 200
11/23 19:58:46 Trace: [client/sonos] av_status
11/23 19:58:46 Trace: [Master bedroom] [zoneplayer/sonos] state from device: PLAYING
11/23 19:58:46 Trace: [Master bedroom] [zoneplayer/sonos] zoneplayer state: Disconnected
11/23 19:58:46 Trace: [music/searchindex] [search-index] removed: 1 albums, 1 tracks, 0 works, 1 performers, 0 labels, 0 genres
11/23 19:58:46 Trace: [music/searchindex] [search-index] added in 20779ms: 1 albums, 1 tracks, 0 works, 1 performers, 0 labels, 0 genres
11/23 19:58:46 Trace: [Master bedroom] [zoneplayer/sonos] state from device: STOPPED
11/23 19:58:47 Debug: [easyhttp] [172] POST to https://metadata.roonlabs.net/1/performers/translate?c=qobuz-ie returned after 600 ms, status code: 200
11/23 19:58:47 Debug: [easyhttp] [171] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 686 ms, status code: 200
11/23 19:58:47 Debug: [easyhttp] [169] POST to https://metadata.roonlabs.net/1/albums/translate?c=qobuz-ie returned after 767 ms, status code: 200
Hopefully it’s an easy fix. I’ve scanned the above for any sensitive data (tokens, etc) and couldn’t see anything but please do redact if necessary.
