I had the Bryston hard drive setup with instructions here, but after a power outage, I have lost connection and cannot restore with same steps of adding the IP address? Not sure what steps to take to restore.
Verify the IP address using Fing, or similar network tool. The IP address could have changed. Check Bryston settings to make sure its Roon Ready, and re-enable the BDP in Roon settings (Settings>Audio).
Great thanks, IP address was different. Got it now.
Glad you’re back up and running…I’ve had similar unplanned IP changes on my BDP-1 until I assigned a fixed address.
