iPad Pro - WiFi to Apple Airport router - wired connection via switch to Zenith
IPad Roon software version 1.6 build 438.
Lumin X1 streamer connected by Ethernet cable directly to Zenith
I’ve been using Roon without issues for about 6 months with this hardware setup. Fairly recently, I’ve found that Roon is slow to reconnect to the music server when I go back to the app on the iPad. This happens whether or not you are currently listening to music. It seems that if you move away from the app to do something else on the iPad, or simply just leave the iPad alone (without closing it Roon down), this annoying connection delay happens if you don’t go back to Roon again within a few minutes. If you switch back after a short time - it connects straight away, as it always seemed to in the past. Maybe this apparent change is as a result of an iOS update? I’m running 13.2.2. Roon does always reconnect eventually - but it is annoying! Any ideas?
I normally use the iPad - so I don’t know much about the connection speed of other devices, but I tried it just now on an iPhone and it connected quickly. I will try it again periodically to see if this is consistent.
If your AirPort supports 5GHz, modify the SSID such that 2.4GHz and 5GHz have different SSID. Then power cycle both the AirPort and iPad Pro. Then in iPad Pro choose the 5GHz WiFi - if it works worse, then switch to the 2.4GHz.
Having been away for a couple of weeks I’ve not been using my system for a while. Whilst away both my iPad an Roon have been updated. I’m now on iOS 13.2.3 and Roon v1.7 build 505. The slow connection issues I’d had previously seem to have gone now! Hopefully that will be the last of the problem. My suspicion was that it was an iOS problem - but I guess I’ll never know for sure.
