Roon nucleus + rev.b—latest OS
Eero mesh router
Synergistic Research Ethernet switch, ayre qx-5, iPad as remote
165000
The Ethernet lights on back of the Nucleus went out this morning. Unit is about 1 yr.old. Can’t connect to Roon. The power button lights up and I can turn the Nucleus off & on via the power button but with no effect on the Ethernet lights. Have unplugged the Nucleus as well as restarting router & modem. The eero dashboard shows the nucleus as not connected. Have hooked up a HDMI cable from Nucleus to a display but the display shows that there is no input. Any help would be appreciated. Thank you.
