Thank you for the post. The team can activate diagnostic logging and investigate why RoonServer is losing the Zone.
To pinpoint the event in logs, we’d require you to submit an approximate timestamp of the last dropout, or the name of the track you attempted to play. Let us know when you’ve next reproduced and we’ll proceed from there.
Thank you, I’ll do that. Meanwhile I’ve checked that the dac has the latest firmware and disabled auto-standby, just to make sure that is not the reason.
Hi, it happened today at 13h30 cet, when starting playing this track:
ps: Disabling the auto-standby on the dac had the opposite effect as the RPi didn’t find the dac (it apparently disables auto power on). Back to previous settings.
I also set the delay time in Roon to allow for any sample rate changes, but didn’t help as well.
Thanks for the timestamps! We’re unfortunately not able to connect to your Roon Server to enable diagnostic mode. Could you please use the directions found here and send over a set of logs to our File Uploader?
