I am also getting short loud bursts of white noise. I just subscribed to Qobuz and turned off my Tidal subscription and these bursts of digital noise have started since. Typically, when starting a song.
Hi @David_Hopwood,
I have split up your post from the previous topic to better assist here.
Can you please let me know some more information here?
- What is your Core specification?
- What endpoint do you experience this issue with?
- Does the same issue happen across multiple endpoints?
- Do local library files exhibit the same behavior?
Thanks,
Noris
I have a Nucleus II and a PS Audio Directstream DAC and, as i said previously, this has just started since I disabled Tidal and enabled Qobuz. I will try a full reboot of all my equipment tomorrow and see if it keeps happening.
Restarting my computer and DAC solved the job once…
Seems to have resolved itself after reboot.
A post was split to a new topic: White noise at the beginning of a track (SonicTransporter + Hugo TT 2)
Hello @David_Hopwood,
Thanks for letting me know that the issue is resolved after a reboot. Just wanted to mention it to you here, I have seen similar symptoms on a PS Audio Directstream DAC due to the firmware version. If this issue occurs again I would check to see if this is not the cause as it was in this similar thread:
Thanks,
Noris
