I am playing MQA tracks from Tidal on my Nucleus HDMI A output. For some reason Roon is telling me the signal path is Low Quality. Any idea why this may be the case?
Thanks for the screenshot, @Blaine_Bulger!
If you go to Settings > Services > TIDAL can you confirm what the quality settings are set to?
It should be ‘Master’, not ‘High’.
I agree. On my computer I have that option. When I work on another computer that is using a Nucleus core and a different Tidal account, the only options in that drop down are Normal and High
I’d guess the associated Tidal account you are signed into isn’t ‘Premium’ or ‘HiFi’ like yours.
Hi @Blaine_Bulger,
I see the Mark’s reply was marked as the solution and I just wanted to follow up and confirm that this ended up being an issue with the TIDAL account that was in use. If you have any questions please let us know!
