Hello Everyone, trying to get some help with a low volume. I have a HiFiBerry studiodac8x as an endpoint. I have it set up to make volume 100 percent on playback start and it is set for Dsp volume. It gets moderately loud but it will not get the amps anywhere close to clipping thanks.
I tried HiFiBerry but it appears I cannot use it how I need to, I am using the DAC as an active crossover and according to what I read HiFiBerry does not support that through Roon. I will have to set up a hardware volume if I go fixed volume as I don’t have any other way to control it.
mjw
(You want nice, supportive? Call a damn helpline.)
5
It’s not entirely clear what you are attempting, but you should be able to use Muse for an active crossover. I’d check out Audio Gear Talk > DSP, and threads by @Graeme_Finlayson.
Fixed volume with device volume I guess that means the device doesn’t do device volume (which is probably good given the issues it caused on the 2 channel devices).
Although it doesn’t take us forward trying to resolve your volume issues.
