Hey ,
i have a problem with the volume when i want to use roon.
I only use Roon on my laptop in combination with an Auralic aries femto. if I use the standard App Lightning DS from Auralic, the volume is quite a bit louder than if I use Roon.
To give an example if I use Roon and set the volume to 75 and then want to turn on another song via the DS, the volume is a lot louder with the next song while all is still at 75. I find this quite annoying when you listen at higher volumes.
