I have a Lyngdorf TDAI-3400 and the LS50 Meta.
What do you use as power cable? Any advice?
I happen to use silver wireworld across my system (‘3400 and ‘2200 for the bass channel) I also use two PS Audio power plants
But, with the benefit of hindsight, I’d put in dedicated mains first - far more cost effective overall IMO, and you get a whole system upgrade that works for future upgrades
I had to have a new consumer unit, plus I used almost 20m of fairly good shielded cable into two double-socket MK boxes
Materials just over £200, labour the same - just over £400 all in
Using the cables @ 10-15% of your budget would imply circa £475-600 just for your amp
So in that sense alone it’s ‘reasonable’ () and in step-change for SQ it was far more significant in my system than any power cable I’ve bought or tried
Regards
