Win10/i5, 16gb/Roon 1.7 build511 32 bit Network Details (Including networking gear model/manufacturer and if on WiFi/Ethernet)
COMPAL CH7465LG router/wifi 5ghz
KEF LS50W OVER WIFI, forced connection to 5ghz as recommended by KEF
“Roon lost control of audio device” error occurs after few seconds of playback. Sometimes restarting playback manually is possible, but it also goes dead and resuming playback is only possible after a restart of either Roon core or LS50w. Then the error occurs again, I restart, etc
Sometimes playback just stops with playback button appearing to play but music not playing and progress bar not moving.
It took several restart of LS50, Roon core, computer to allow normal playback without interruptions; now it seems to work fine for the last 30 minutes.
yesterday it worked perfectly fine for 12 hours in the same setup.
Still expecting Roon support to have a look at this as it is not a solved issue. The interruptions still happen at random intervals requiring re-start of either speakers or Roon server. I expect this is a Roon+Kef issue, I would like some feedback from Roon before I contact Kef.
Thank you
Here also, still a problem!
Only via Wi-fi and ethernet… via usb it works perfectly, however via usb you can’t change the volume, you have to use the kef app.
