I only play through Tidal at the moment and even with 44kHz 16bit I have this issue.
My network setup is as follows:
Roon server runs on a Linux server hardwired to a switch (HP 1820 24 ports)
KEF LS50W are connected hardwired to a switch (Cisco C2960CG)
HP 1820 and Cisco are connected via 2GB LACP aggregate.
Wireless connection is through Ubiquiti UAP-AC-pro connected to HP 1820 switch
All are on the same VLAN.
iPad is connected to Ubiquiti wireless
KEFs are running the latest firmware (15 oct 2018).
Some logging:
Some logging:
05/13 13:21:53 Trace: [client/kef] av_status
05/13 13:21:53 Trace: [LS50W] [zoneplayer/kef] state from device: PLAYING
05/13 13:21:53 Trace: [LS50W] [zoneplayer/kef] zoneplayer state: WaitForStatus
05/13 13:21:53 Trace: [endpoint/kef/uuid:5f9ec1b3-ed59-1900-4530-84171500caaf] check zone coordinator, device coordinator: 5f9ec1b3-ed59-1900-4530-84171500caaf, roon coordinator: 5f9ec1b3-ed59-1900-4530-84171500caaf
05/13 13:21:53 Trace: [LS50W] [zoneplayer/kef] State transition WaitForStatus => Playing
05/13 13:21:56 Trace: [LS50W] [Lossless, 16/44 TIDAL FLAC => 16/44] [100% buf] [PLAYING @ 0:03/4:24] Under the Bridge - Red Hot Chili Peppers
05/13 13:21:56 Trace: [zone LS50W] Previous
05/13 13:21:56 Info: [zone LS50W] OnPlayFeedback Stopped
05/13 13:21:56 Trace: [LS50W] [zoneplayer/kef] endstream, zp state: Playing
05/13 13:21:56 Trace: [LS50W] [zoneplayer/kef] State transition Playing => Disconnected
05/13 13:21:56 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
05/13 13:21:56 Trace: [LS50W] [zoneplayer/kef] endstream, zp state: Disconnected
05/13 13:21:56 Trace: [LS50W] [Lossless, 16/44 TIDAL FLAC => 16/44] [100% buf] [LOADING @ 0:00] Smells Like Teen Spirit - Nirvana
05/13 13:21:56 Info: [audio/env] [zoneplayer] All streams were disposed
05/13 13:21:56 Trace: [LS50W] [zoneplayer/kef] got http request while zoneplayer was in non-playing state, closing connnection
05/13 13:21:56 Trace: [LS50W] [zoneplayer/kef] transaction canceled, isplaying: False, did stream end: False, tx path: /ccdb6339ee09484bb713df941e8ece3a/Roon1f91f1fef4a74296b74f52a07c309408.flac, stream path: /ccdb6339ee09484bb713df941e8ece3a/Roon1f91f1fef4a74296b74f52a07c309408.flac, method: Get
05/13 13:21:56 Trace: [dbperf] flush 0 bytes, 0 ops in 1 ms (cumulative 0 bytes, 0 ops in 39 ms)
/LS50
05/13 13:22:24 Trace: [LS50W] [Lossless, 16/44 TIDAL FLAC => 16/44] [100% buf] [PLAYING @ 0:00] Come as You Are - Nirvana
05/13 13:22:24 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:25 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:26 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:27 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:28 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:29 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:29 Trace: [LS50W] [Lossless, 16/44 TIDAL FLAC => 16/44] [100% buf] [PLAYING @ 0:00] Come as You Are - Nirvana
05/13 13:22:30 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:31 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:32 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:32 Info: [stats] 2316mb Virtual, 256mb Physical, 84mb Managed, 0 Handles, 70 Threads
05/13 13:22:33 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:34 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:35 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:35 Trace: [LS50W] [Lossless, 16/44 TIDAL FLAC => 16/44] [100% buf] [PLAYING @ 0:00] Come as You Are - Nirvana
05/13 13:22:36 Trace: [LS50W] [zoneplayer/kef] position timer, not triggering 0 position stream ended for KEF speaker
05/13 13:22:36 Trace: [rnet/RnetJsonClient] no data received for >10000ms. Killing connection.
05/13 13:22:36 Warn: [rnet/RnetJsonClient] error writing to connection
05/13 13:22:36 Trace: [push] restarting connection (Unable to read data from the transport connection: interrupted.)
05/13 13:22:36 Trace: [push] retrying connection in 99075ms
