This is normal behavior. The important thing for you is that the USB +5V is off. The light (which represents the OpenHome standby state) does not matter. It has always behaved like this for Lumin series since 2012, since no other model has a light. Now that you mentioned it, I’d need to discuss this with the team to see if a design change is suitable or not.
Spotify Lossless is 24bit/44.1kHz - flac on the computer and iphone. But, with my U2 Mini, I’m only getting 16bit/44.1kHz - flac. I’ve disabled Spotify connect, and renabled it, restarted it, it’s still streaming across at 16bit/44.1kHz. - Am doing something wrong? Or is there something else that I need to do. It’s running firmware 21.0, no volume control, no audio normalization, no resampling. Qobuz streams all and so does roon. It’s not an issue, just curious regarding it.
Anyone else with a U2 mini & spotify seeing the same thing? or its fine at your end. thanks
Soon we will have an update to U2-series, P1MINI, T3X, T3, D3 for 24-bit Spotify. The other models will remain at 16 bit.
There are very few 24-bit tracks from Spotify.
All good, many thanks Peter for the update.
Lumin Firmware 21.1 supports 24-bit Spotify Lossless for U2-series P1MINI T3X T3 D3.
Older CPU may not get 24-bit unless Spotify helps with custom SDK.
working great - thanks ![]()
In Firmware 15.3 you did an improvement for Spotify (not lossless) is this valid for lossless also or do you need to do some adjustment? I’m asking because as for now Spotify lossless don’s sound as good as the same releases on Qobuz in my system (44.1./16). Spotify lossless is just released so the question is if this is good as it gets on Lumin or can we expect some improvement in fw in the future?
Please make sure Spotify Audio Normalization is disabled. It is already proven bit perfect, if your track sounds better from Qobuz please keep Qobuz.
Ok some more data points.
iPhone to p1 mini Spotify when play stops the blue light remains on and usb voltage is off
Roon still shows the Lumin is on and turning off via the volume icon does drop to red led with I think a relay click in the p1 mini.
I have changed this behavior already - are you running the latest Firmware 21.1 released last Friday?
I am now ![]()
Please update to Firmware 21.1b and retry.
I canceled my subscription to Spotify (expired 2 days ago) after your last replay, and some more testing. Can explain what is changed with the new firmware? Think I will just use Qobuz and my Lumin in roononly mode for now.
While some of our major competitors are still struggling with supporting Spotify Lossless on their current models, I am releasing 24-bit Spotify Lossless support to all Lumin models with Firmware 22, even including the original Lumin A1 2012 that we released 13.5 years ago. Note that different models get the firmware at slightly different times.
And this is why I am now a U2X customer. Top tier support as always ![]()
there is a bug at least on the X2 and the D2 where the display shows differently to the app for Spotify…the eversolo plays at 44.1 16bit for the same stream
X2 and P1mini are both s/w 21.3c and D2 is only 21.1b
all show no s/w update needed.
should the X2 and P1 mini be getting updates already? or am I being to eager and just have to wait a few days.
X2 display
This is the Lumin App
as an indication the Eversolo playing the same stream from the same phone and playlist
I’ll check it again when I have access to X2 tomorrow at work.
From your photos, your X2 display and the Lumin app display are consistent.
Meanwhile, please re-perform the steps in post #8. You do not need to wait for the update. Your models have 24-bit Spotify support since some time ago.
In particular, quality setting needs to be done for every hardware, repeated as many times as needed. Then you need to clear the cache.
Especially with the X2, Lumin DSD upsampling should not be needed. Please turn it off. You should see Spotify FLAC in the display.
I tested your track on X2. It correctly shows Spotify FLAC.
Bingo it was the per device setting that screwed me up…the d2 got the 22.0 update just now and thats all good showing FLAC now too.
Well done to the team getting this retrograded to the older devices. this is one of the many reasons Lumin is just my go to for streamers and Dac combo.
Just updated the oldest of my Lumins….a 2013 D1 and using coax out to a Holo Audio CYAN 2 just for giggles I thought I might play with 192/24 and DSD64 from roon. Even with DSD and LeedH volume no issue….Props and credit to Lumin team for backward support in older products. I know Spotify now works too but the old gear just keeps up with big boys in the house.
