I am trying to connect my X1 with fibre-net to wring the best possible quality out of this spectacular machine, but I am stuck at the moment.
My setup is as follows:
TP-Link T1500G-10PS 8-Port Gigabit PoE L2 Managed Switch 2xSFP
with 2 of these modules (TP-Link-TL-SM311LS SFP-Fiber-Module-Single)
one in the switch, one in the X1
The cable is a LWL Patch cable 6 m LC - LC yellow 9/125 OS1/OS2 Duplex Singlemode LSZH, Uniboot, Low-loss, LCR
The switch seems to be working with this setup and shows the connection as functional in its web interface:
but all I get from the Lumin is a network error
With the Lumin app the X1 is not visible and Roon does not find it either.
Connected via copper ethernet, however, everything works as expected.
I did a reset of the switch and the Lumin which did not change anything.
Probably I made a mistake somewhere, but where …?
Does anyone have any ideas?
