Mac OS Tahoe 26.2 network devices not showing in Roon Audio settings (ref#PY82P7)
· A connected audio device is not appearing in Roon
· Network - Ethernet
· RoonReady
· No, it does not show up there
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
Try to disable any additional networking interfaces on your RoonServer machine.
· Disabling network interfaces had no change in behavior
Check to make sure RoonReady mode is selected on the device.
· I've checked this and the issue remains
· 12/16/2025
· Cambridge Audio CXN(2), Bluesound Power Node
Running Mac OS Tahoe 26.2. Network devices – Blue OS Powernode and Cambridge Audio CXN (V2) – are not showing in the Roon Audio settings.
CXN connected by ethernet, Powernode is wifi. both are showing on the network, just not in Roon
Orbi RBR20 mesh and hardwired ethernet
Sorted!
Update to Tahoe 26.2 turned off local network access for Roon.
Thanks @David_Morris2. How do I change it?
Disregard. Privacy and security → local network access → toggle back on.
