Macbook Pro M1
16gb Memory
Connected via home Wifi, no VPN
Roon library is located on Synology Nas
Roon core is running on a NUC PC
After the latest Roon update I am no longer able to enable my system output to listen to music through my laptop. My library loads and I can see all my music, so the connection between my laptop and core is working correctly. I can also play music through my Sonos via Roon (when enabled). For some reason though the system output on my Macbook will not enable, where it worked flawlessly before. I’m able to stream music through all other services. Let me know what you suggest to fix it and thanks for the support!
