· WiFi
· I don't have a System Output available, but I'd like to keep troubleshooting
· Network - WiFi
· Airplay
Since this is an Airplay Zone, have you tried toggling Airplay Compatibility Mode for this Zone in the Device Setup window?
· There is no change in behavior.
· Yes, it shows up there, but it isn't Enabled
Does the "Enable" button unlock the Zone?
· I pressed Enable, but the Zone remains disabled
· Only one output type is affected while the other output type works as expected
· It's been going on for over a week.
· Macbook Air, M3
I can't connect my macbook as an audio device. The audio section in settings keeps flickering and I can't make any changes. Please advise.
I'm using my internet providers modem and router (Verizon).
