roon core: HP Microserver, Intel Xeon E3-1230v2, 16 GByte RAM, Windows 10 Pro
remote: Gigabyte X570 Master, AMD 3800x, 64 GByte RAM, Windows 10 Pro running roon remote
AVM Fritz!box 7590, 3 AVM 1750E repeaters in mesh configuration
RME ADI-2 DAC, USB
Setting up an new machine at the office with AMD 3800x that does NOT show up in roon at all. Nor does the DAC that is connected.
Audio seems ok, sound settings look fine, jriver Mediacenter works just fine with asio and wasapi output.
roon remote does not show the machine it is running on at all, nor does it show connected audio devices (RME or onboard audio).
It does show all networked devices plus the devices connected to core. Remote control of other nodes works just fine.
Please advise.
Joachim
