ROCK on NUC upated fine after reboot.
1.7 is awesome, thank you Roon!
MacOS won’t update.
iOS has updated no problem.
Any ideas?
Mike
Have you tried downloading manually from Roon and reinstalling using the dmg?
I hadn’t @dpstjp so thanks for suggestion.
I just opened Roon again on my Mac now and this time 1.7 downloaded and worked perfectly. Weird. But good.
I have another glitch trying to stream BBC Radio 6 Music. Used to work OK. Will try removing and reinstalling.
Thanks for helping
Load radio 6 from the new live radio section
