I just tried playing W.O.L.D by Harry Chapin via Roon from Tidal. Failed with network error. Retried and got error “This track is currently not available from Tidal”, Then Too many playback errors, etc.
Meanwhile Tidal app on the same system played it without error.
here is the log from around that time:
04/04 15:00:12 Info:
--[ SignalPath ]---------------------------------------------
SignalPath Quality = Lossless
Elements:
Source Format=Flac 44100/16/2 Quality=Lossless
Raat Device=snd_rpi_rpi_dac
Output OutputType=Local_Alsa Quality=Lossless SubType= Model=snd_rpi_rpi_dac
04/04 15:00:12 Trace: [roonapi] [apiclient 192.168.1.53:39534] CONTINUE Changed {"zones_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","display_name":"Pi","outputs":[{"output_id":"17011c46b181259d2cf5a5b5cbb212f4e5dd","zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","can_group_with_output_ids":["17011c46b181259d2cf5a5b5cbb212f4e5dd"],"display_name":"Pi","source_controls":[{"control_key":"1","display_name":"snd_rpi_rpi_dac","supports_standby":false,"status":"indeterminate"}]}],"state":"stopped","is_next_allowed":false,"is_previous_allowed":true,"is_pause_allowed":false,"is_play_allowed":false,"is_seek_allowed":false,"queue_items_remaining":0,"queue_time_remaining":0,"settings":{"loop":"disabled","shuffle":false,"auto_radio":false}}],"zones_seek_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","queue_time_remaining":0}]}
04/04 15:00:13 Trace: [streamingmediafile] finished caching http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInOWI3Zjc0YWI1NzhmMzdhYTI4YjZjZTdiOTZkOGQ5MjRfNjEubXA0/0.flac
04/04 15:00:13 Debug: [smc] [zoneplayer:3] Removing ordinal 124
04/04 15:00:13 Debug: [smc] [zoneplayer:3] Destroyed domain
04/04 15:00:15 Trace: [zone Pi] Playing 1 Items
04/04 15:00:15 Trace: [zone Pi] Selecting Source state=Stopped
04/04 15:00:15 Info: [zone Pi] OnPlayFeedback Stopped
04/04 15:00:15 Debug: [smc] [zoneplayer:3] Created domain
04/04 15:00:15 Debug: [smc] [zoneplayer:3] Removing ordinal 124
04/04 15:00:15 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
04/04 15:00:15 Debug: [smc] [zoneplayer:3] Destroyed domain
04/04 15:00:15 Trace: [zone Pi] Playing TransportItem
04/04 15:00:15 Trace: [zone Pi] queue got oversized. trimming 1 items from start
04/04 15:00:15 Debug: [zone Pi] Remove(1 items, for_replace=False)
04/04 15:00:15 Info: after removeall ordered count 5000 shuffle count 5000
04/04 15:00:15 Info: [audio/env] [zoneplayer] All streams were disposed
04/04 15:00:15 Debug: [raat/tcpaudiosource] disconnecting
04/04 15:00:15 Info: [audio/env] [zoneplayer -> stream -> endpoint] All streams were disposed
04/04 15:00:15 Info: sleep 39ms after flush
04/04 15:00:15 Trace: [Pi] [Lossless, 16/44 TIDAL FLAC => 16/44] [1% buf] [LOADING @ 0:00] W.O.L.D. - The Chapin Family
04/04 15:00:15 Trace: [musicpowerstate] music is playing, preventing idle sleep
04/04 15:00:15 Trace: [roonapi] [apiclient 192.168.1.53:39534] CONTINUE Changed {"zones_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","display_name":"Pi","outputs":[{"output_id":"17011c46b181259d2cf5a5b5cbb212f4e5dd","zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","can_group_with_output_ids":["17011c46b181259d2cf5a5b5cbb212f4e5dd"],"display_name":"Pi","source_controls":[{"control_key":"1","display_name":"snd_rpi_rpi_dac","supports_standby":false,"status":"indeterminate"}]}],"state":"loading","is_next_allowed":false,"is_previous_allowed":true,"is_pause_allowed":true,"is_play_allowed":false,"is_seek_allowed":false,"queue_items_remaining":1,"queue_time_remaining":321,"settings":{"loop":"disabled","shuffle":false,"auto_radio":false},"now_playing":{"seek_position":null,"length":321,"one_line":{"line1":"W.O.L.D. - The Chapin Family"},"two_line":{"line1":"W.O.L.D.","line2":"The Chapin Family"},"three_line":{"line1":"W.O.L.D.","line2":"The Chapin Family","line3":"Harry Chapin: A Celebration In Song (Volume I)"},"image_key":"4e58d73e0e90052294a1425dbcbc939078ed042d692b685c5497ac5628be8b4728dce89c57a67c6fd1c4aed54461b38520bfb5c5af359d95658b081aae78fb5ccc6f66165d6830fd8f9aa1f74f1adba372aaa53929187f056a1f0c3433db5473da3010fe0f5a8e69fae84b1dfb5c271a"}}],"zones_seek_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","queue_time_remaining":321,"seek_position":null}]}
04/04 15:00:15 Trace: [dbperf] flush 0 bytes, 0 ops in 9 ms (cumulative 1516473877 bytes, 757531 ops in 646100 ms)
04/04 15:00:15 Warn: [easyhttp] [539] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [542] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [543] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [544] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [545] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [546] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [547] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [549] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [550] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [551] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [553] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Warn: [easyhttp] [552] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:15 Trace: [tidal/http] GET https://api.tidal.com/v1/tracks/46250560/playbackinfopostpaywall?countryCode=US&audioquality=HI_RES&assetpresentation=FULL&playbackmode=STREAM => Success
04/04 15:00:15 Trace: [tidal/http] GET https://api.tidal.com/v1/tracks/46250560?countryCode=US => Success
04/04 15:00:15 Info: [Pi] [zoneplayer] Playing: http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInZDM3MjU1ZjU1MDNkYmQ5MDA4YjFjOTFhMTBjYzhkN2JfNjEubXA0/0.flac
04/04 15:00:15 Debug: [smc] [zoneplayer:3] Adding ordinal 125
04/04 15:00:15 Debug: [easyhttp] [548] GET to https://metadata.roonlabs.net/1/performers/122:0:MN0002331031/refs?c=tidal-us returned after 129 ms, status code: 200
04/04 15:00:15 Debug: GMS: saving nav stack
04/04 15:00:15 Debug: GMS: trying to save nav stack, but nav stack stuff was in progress
04/04 15:00:15 Debug: GMS: done saving nav stack
04/04 15:00:16 Trace: [streamingmediafile] retrying request due to Error writing headers
04/04 15:00:16 Debug: [easyhttp] [541] GET to https://imagecache.roonlabs.net/im/1/albums/a6003436323530353538/cover/402.jpg returned after 361 ms, status code: 200
04/04 15:00:16 Debug: [easyhttp] [540] GET to https://imagecache.roonlabs.net/im/1/albums/a6003436323530353538/cover/402.jpg returned after 600 ms, status code: 200
04/04 15:00:17 Trace: [streamingmediafile] retrying request due to Error writing headers
04/04 15:00:17 Warn: [streamingmediafile] caching http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInZDM3MjU1ZjU1MDNkYmQ5MDA4YjFjOTFhMTBjYzhkN2JfNjEubXA0/0.flac failed: System.Net.WebException: Error writing headers ---> System.IO.IOException: Unable to write data to the transport connection: The socket is not connected. ---> System.Net.Sockets.SocketException: The socket is not connected
at System.Net.Sockets.Socket.EndSend (System.IAsyncResult asyncResult) [0x00012] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x00057] in <bc69ad8632744cfba18f9705e53c6302>:0
--- End of inner exception stack trace ---
at System.Net.Sockets.NetworkStream.EndWrite (System.IAsyncResult asyncResult) [0x0009b] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.IO.Stream+<>c.<BeginEndWriteAsync>b__58_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <ba70b91736bd40cb990a357097dba9c3>:0
at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult)
at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <ba70b91736bd40cb990a357097dba9c3>:0
--- End of stack trace from previous location where exception was thrown ---
at System.Net.WebRequestStream.SetHeadersAsync (System.Boolean setInternalLength, System.Threading.CancellationToken cancellationToken) [0x001d4] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.WebRequestStream.SetHeadersAsync (System.Boolean setInternalLength, System.Threading.CancellationToken cancellationToken) [0x00221] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.WebRequestStream.Initialize (System.Threading.CancellationToken cancellationToken) [0x000d5] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.WebOperation.Run () [0x0012c] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <bc69ad8632744cfba18f9705e53c6302>:0
at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00020] in <bc69ad8632744cfba18f9705e53c6302>:0
at Sooloos.Media.StreamingMediaFileImpl+<>c__DisplayClass11_1.<_StartBuffering>b__1 (System.IAsyncResult resp_ar) [0x00002] in <8061a44bcbb94e199a23491d999d3f88>:0
04/04 15:00:17 Error: [seekableurimediafile] while determining length: System.IO.IOException: streaming media failed due to network
at Sooloos.Media.StreamingMediaFileImpl.get_Length () [0x00038] in <8061a44bcbb94e199a23491d999d3f88>:0
at Sooloos.Media.StreamingMediaFile.get_Length () [0x00000] in <8061a44bcbb94e199a23491d999d3f88>:0
at Sooloos.Media.CachingSeekableUriMediaFile.LengthCallback (System.IntPtr userdata, System.Int64& out_length) [0x00017] in <8061a44bcbb94e199a23491d999d3f88>:0
04/04 15:00:17 Debug: [smc] [zoneplayer:3] Removing ordinal 125
04/04 15:00:17 Debug: [smc] [zoneplayer:3] Destroyed domain
04/04 15:00:17 Warn: [zoneplayer] Corrupt Media Detected
04/04 15:00:17 Info: [Pi] [zoneplayer] Open Result (Playing):Result[Status=CorruptMedia]
04/04 15:00:17 Warn: [zoneplayer] couldn't play URL http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInZDM3MjU1ZjU1MDNkYmQ5MDA4YjFjOTFhMTBjYzhkN2JfNjEubXA0/0.flac?Expires=1586030415&Signature=OlglDjZKViIzEAT9A~rFVkO5PvtrMbH-cKYbHE-WvcdX95XoS5UGJgsQlkxvDpFVFbq9-AtMJge6NKrM2tVsQVAnfdHcOhsuJALmaFdWvLrWAz8ZKuQ26Hw~fpfTKnkpTpGUSOgoB-FMWuAbStpQlO696Z00vRNxDWpOlb3gtfjeC2iTNJtxlqkSwjxW9G-7aorjaO47r7V2hjzSLoIPEdaCXqPEQEgAEaBCaHG2dy4MfARlZwIEN0gzBUn8SSQHtlZyplP~wbk~-Ar7xFiUw665j3uMECv~8a260CACbJuxA8lI-8WkvGxXBVVDIXab0pAG3yTHho~w9GWOCf5aFg__&Key-Pair-Id=APKAIZ3WPBE4R6SP555A: corrupt media
04/04 15:00:17 Warn: Track Stopped Due to Bad Media
04/04 15:00:17 Info: [zone Pi] OnPlayFeedback StoppedEndOfMediaUnnatural
04/04 15:00:17 Debug: [zone Pi] _Advance
04/04 15:00:17 Trace: [Pi] [Lossless, 16/44 TIDAL FLAC => 16/44] [1% buf] [STOPPED @ 0:00]
04/04 15:00:17 Trace: [roonapi] [apiclient 192.168.1.53:39534] CONTINUE Changed {"zones_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","display_name":"Pi","outputs":[{"output_id":"17011c46b181259d2cf5a5b5cbb212f4e5dd","zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","can_group_with_output_ids":["17011c46b181259d2cf5a5b5cbb212f4e5dd"],"display_name":"Pi","source_controls":[{"control_key":"1","display_name":"snd_rpi_rpi_dac","supports_standby":false,"status":"indeterminate"}]}],"state":"stopped","is_next_allowed":false,"is_previous_allowed":true,"is_pause_allowed":false,"is_play_allowed":false,"is_seek_allowed":false,"queue_items_remaining":0,"queue_time_remaining":0,"settings":{"loop":"disabled","shuffle":false,"auto_radio":false}}],"zones_seek_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","queue_time_remaining":0}]}
04/04 15:00:17 Debug: GMS: saving nav stack
04/04 15:00:17 Debug: GMS: done saving nav stack
04/04 15:00:19 Trace: [zone Pi] Playing 1 Items
04/04 15:00:19 Trace: [zone Pi] Selecting Source state=Stopped
04/04 15:00:19 Info: [zone Pi] OnPlayFeedback Stopped
04/04 15:00:19 Trace: [zone Pi] Playing TransportItem
04/04 15:00:19 Trace: [zone Pi] queue got oversized. trimming 1 items from start
04/04 15:00:19 Debug: [zone Pi] Remove(1 items, for_replace=False)
04/04 15:00:19 Info: after removeall ordered count 5000 shuffle count 5000
04/04 15:00:19 Trace: [Pi] [Lossless, 16/44 TIDAL FLAC => 16/44] [1% buf] [LOADING @ 0:00] W.O.L.D. - Harry Chapin
04/04 15:00:19 Trace: [musicpowerstate] music is playing, preventing idle sleep
04/04 15:00:19 Trace: [roonapi] [apiclient 192.168.1.53:39534] CONTINUE Changed {"zones_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","display_name":"Pi","outputs":[{"output_id":"17011c46b181259d2cf5a5b5cbb212f4e5dd","zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","can_group_with_output_ids":["17011c46b181259d2cf5a5b5cbb212f4e5dd"],"display_name":"Pi","source_controls":[{"control_key":"1","display_name":"snd_rpi_rpi_dac","supports_standby":false,"status":"indeterminate"}]}],"state":"loading","is_next_allowed":false,"is_previous_allowed":true,"is_pause_allowed":true,"is_play_allowed":false,"is_seek_allowed":false,"queue_items_remaining":1,"queue_time_remaining":312,"settings":{"loop":"disabled","shuffle":false,"auto_radio":false},"now_playing":{"seek_position":null,"length":312,"one_line":{"line1":"W.O.L.D. - Harry Chapin"},"two_line":{"line1":"W.O.L.D.","line2":"Harry Chapin"},"three_line":{"line1":"W.O.L.D.","line2":"Harry Chapin","line3":"Some More Stories"},"image_key":"4e58d73e0e90052294a1425dbcbc939078ed042d692b685c5497ac5628be8b4728dce89c57a67c6fd1c4aed54461b3855a6b4b4f0c2e9a866c32cfb176ce6517f2667968ab3c51e8e2889b620e16da17a1a4328ff8ed79457884317a1512612f7b482775f251c3dce26db36a17ff23a1","artist_image_keys":["4e58d73e0e90052294a1425dbcbc939078ed042d692b685c5497ac5628be8b4794fab8f5b705d380d5942fd6b87d02d19623299361ca3e2313368d44331d36fbfd70a099ed0d62e9ba9bd22eeea558fd53384f00f57641de27978be7c1d7f64ed34718c0e760f939d06cec15f8bac48d"]}}],"zones_seek_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","queue_time_remaining":312,"seek_position":null}]}
04/04 15:00:19 Warn: [easyhttp] [555] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:19 Warn: [easyhttp] [556] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:19 Warn: [easyhttp] [559] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:19 Warn: [easyhttp] [560] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:19 Trace: [tidal/http] GET https://api.tidal.com/v1/tracks/130325542/playbackinfopostpaywall?countryCode=US&audioquality=HI_RES&assetpresentation=FULL&playbackmode=STREAM => Success
04/04 15:00:19 Debug: GMS: saving nav stack
04/04 15:00:19 Debug: GMS: trying to save nav stack, but nav stack stuff was in progress
04/04 15:00:19 Debug: GMS: done saving nav stack
04/04 15:00:19 Trace: [tidal/http] GET https://api.tidal.com/v1/tracks/130325542?countryCode=US => Success
04/04 15:00:19 Info: [Pi] [zoneplayer] Playing: http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInMmE5NzYyYTA1ZTIxZTZlYmRhYTE0ZTkyYzZmNjJlMDJfNjEubXA0/0.flac
04/04 15:00:19 Debug: [smc] [zoneplayer:3] Created domain
04/04 15:00:19 Debug: [smc] [zoneplayer:3] Adding ordinal 126
04/04 15:00:19 Debug: [easyhttp] [554] GET to https://metadata.roonlabs.net/1/tracks/168:0:130325542/lyrics returned after 138 ms, status code: 404
04/04 15:00:19 Trace: [streamingmediafile] retrying request due to Error writing headers
04/04 15:00:19 Debug: [easyhttp] [558] GET to https://imagecache.roonlabs.net/im/1/albums/a600313330333235353430/cover/402.jpg returned after 436 ms, status code: 200
04/04 15:00:20 Trace: [streamingmediafile] retrying request due to Error writing headers
04/04 15:00:20 Debug: [easyhttp] [557] GET to https://imagecache.roonlabs.net/im/1/albums/a600313330333235353430/cover/402.jpg returned after 578 ms, status code: 200
04/04 15:00:21 Trace: [streamingmediafile] retrying request due to Error writing headers
04/04 15:00:21 Warn: [streamingmediafile] caching http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInMmE5NzYyYTA1ZTIxZTZlYmRhYTE0ZTkyYzZmNjJlMDJfNjEubXA0/0.flac failed: System.Net.WebException: Error writing headers ---> System.IO.IOException: Unable to write data to the transport connection: The socket is not connected. ---> System.Net.Sockets.SocketException: The socket is not connected
04/04 15:00:21 Error: [seekableurimediafile] while determining length: System.IO.IOException: streaming media failed due to network
04/04 15:00:21 Debug: [smc] [zoneplayer:3] Removing ordinal 126
04/04 15:00:21 Debug: [smc] [zoneplayer:3] Destroyed domain
04/04 15:00:21 Warn: [zoneplayer] Corrupt Media Detected
04/04 15:00:21 Info: [Pi] [zoneplayer] Open Result (Playing):Result[Status=CorruptMedia]
04/04 15:00:21 Warn: [zoneplayer] couldn't play URL http://sp-pr-cf.audio.tidal.com/mediatracks/CAEaKRInMmE5NzYyYTA1ZTIxZTZlYmRhYTE0ZTkyYzZmNjJlMDJfNjEubXA0/0.flac?Expires=1586030419&Signature=baR9zTJNkCbV6CViPYfjPMtNYMF88cyYUoSKi-q0tNLojOVhLPpWJSgh-24qFWmH~WhRqq5agBpyZ0-mHshdhZlUJe1VtkOK8L-A4qxlAQzvs31PfUzOkdiUVm~zGUpJvkoqf2-LN4FFFNuIAb9DUoSVoNZ~ntncnNJL2SbRL2p0KwtZmtW21EJnPNb7F5WV7aj1uaL7SYUSTcMVLBAkARDd2tavkZKHRNqbLWw6uUE6OUpqdq6N3F2ebahJW0aKAksgojCHZ3Qebxujv9YfLzwX95u72D~U1i1aSbkHDrvJv0W9ZJp9AVzCj-zbKOZ9wq~HqZTsVb1FO1ydm4unoA__&Key-Pair-Id=APKAIZ3WPBE4R6SP555A: corrupt media
04/04 15:00:21 Warn: Track Stopped Due to Bad Media
04/04 15:00:21 Info: [zone Pi] OnPlayFeedback StoppedEndOfMediaUnnatural
04/04 15:00:21 Debug: [zone Pi] _Advance
04/04 15:00:21 Trace: [Pi] [Lossless, 16/44 TIDAL FLAC => 16/44] [1% buf] [STOPPED @ 0:00]
04/04 15:00:21 Trace: [roonapi] [apiclient 192.168.1.53:39534] CONTINUE Changed {"zones_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","display_name":"Pi","outputs":[{"output_id":"17011c46b181259d2cf5a5b5cbb212f4e5dd","zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","can_group_with_output_ids":["17011c46b181259d2cf5a5b5cbb212f4e5dd"],"display_name":"Pi","source_controls":[{"control_key":"1","display_name":"snd_rpi_rpi_dac","supports_standby":false,"status":"indeterminate"}]}],"state":"stopped","is_next_allowed":false,"is_previous_allowed":true,"is_pause_allowed":false,"is_play_allowed":false,"is_seek_allowed":false,"queue_items_remaining":0,"queue_time_remaining":0,"settings":{"loop":"disabled","shuffle":false,"auto_radio":false}}],"zones_seek_changed":[{"zone_id":"16011c46b181259d2cf5a5b5cbb212f4e5dd","queue_time_remaining":0}]}
04/04 15:00:21 Debug: GMS: saving nav stack
04/04 15:00:21 Debug: GMS: done saving nav stack
04/04 15:00:23 Debug: UI-FORCE-LAZY: mode: viewall
04/04 15:00:23 Debug: UI-FORCE-LAZY: mode: albumdetails
04/04 15:00:23 Debug: UI-FWD: mode: albumdetails
04/04 15:00:23 Debug: GMS: saving nav stack
04/04 15:00:23 Debug: UI-NAV: album details / album: [object Sooloos.Broker.Metadata.MetadataAlbumLite] / bookmarkdata:
04/04 15:00:23 Warn: [easyhttp] [561] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:23 Warn: [easyhttp] [562] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:23 Warn: [easyhttp] [563] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:23 Warn: [easyhttp] [564] web exception without response: Error: SecureChannelFailure (Unable to write data to the transport connection: The socket is not connected.)
04/04 15:00:23 Debug: GMS: done saving nav stack
04/04 15:00:25 Info: [stats] 18027mb Virtual, 5120mb Physical, 3035mb Managed, 105 Threads, FDs
04/04 15:00:26 Trace: [zone] no playback for 5s, suspending to release audio device
04/04 15:00:26 Trace: [zone Pi] Suspend
04/04 15:00:26 Trace: [zone Pi] Stop
04/04 15:00:26 Info: [zone Pi] OnPlayFeedback Stopped
04/04 15:00:37 Trace: [library] endmutation in 31ms
04/04 15:00:40 Info: [stats] 18014mb Virtual, 5129mb Physical, 3050mb Managed, 98 Threads, FDs
04/04 15:00:47 Trace: [roonapi] [apiclient 192.168.1.53:39534] CONTINUE Changed {"message":"Running (17)","is_error":false}
04/04 15:00:56 Info: [stats] 18004mb Virtual, 5130mb Physical, 3052mb Managed, 93 Threads, FDs
04/04 15:01:11 Info: [stats] 18008mb Virtual, 5137mb Physical, 3064mb Managed, 95 Threads, FDs
04/04 15:01:22 Debug: UI-BACK: mode: unifiedsearch
04/04 15:01:22 Debug: GMS: saving nav stack
04/04 15:01:23 Debug: GMS: done saving nav stack
04/04 15:01:23 Trace: [broker/accounts] doing auth refresh in EnsureAuthReady, next=4/4/2020 8:01:23 PM
04/04 15:01:23 Trace: [broker/accounts] refreshing account info for email='pbgalvin@gmail.com' userid=6fbfe46f-171c-4fb5-9a49-74c86cf998fd
04/04 15:01:23 Trace: [fiveaccountserver] POST https://accounts5.roonlabs.com/accounts/3/login
04/04 15:01:23 Trace: [fiveaccountserver] BODY token=ee8e1139-aecd-4de8-bf08-ac56b6bf19c0
04/04 15:01:23 Trace: Successful POST response from https://accounts5.roonlabs.com/accounts/3/login
04/04 15:01:23 Trace: [fiveaccountserver] GOT {"status":"Success","userid":"6fbfe46f-171c-4fb5-9a49-74c86cf998fd","token":"ee8e1139-aecd-4de8-bf08-ac56b6bf19c0","expiration":30,"email":"pbgalvin@gmail.com","groups":[]}
04/04 15:01:23 Warn: [broker/accounts] failed to auth: Result[Status=NetworkError]
04/04 15:01:26 Info: [stats] 18006mb Virtual, 5141mb Physical, 3071mb Managed, 94 Threads, FDs
04/04 15:01:28 Trace: [broker/accounts] refreshing account info for email='pbgalvin@gmail.com' userid=6fbfe46f-171c-4fb5-9a49-74c86cf998fd
04/04 15:01:28 Trace: [fiveaccountserver] POST https://accounts5.roonlabs.com/accounts/3/login
04/04 15:01:28 Trace: [fiveaccountserver] BODY token=ee8e1139-aecd-4de8-bf08-ac56b6bf19c0
04/04 15:01:28 Trace: Successful POST response from https://accounts5.roonlabs.com/accounts/3/login
04/04 15:01:28 Trace: [fiveaccountserver] GOT {"status":"Success","userid":"6fbfe46f-171c-4fb5-9a49-74c86cf998fd","token":"ee8e1139-aecd-4de8-bf08-ac56b6bf19c0","expiration":30,"email":"pbgalvin@gmail.com","groups":[]}
04/04 15:01:29 Trace: [fiveaccountserver] GET https://accounts5.roonlabs.com/accounts/3/profileslist?token=ee8e1139-aecd-4de8-bf08-ac56b6bf19c0
04/04 15:01:29 Trace: [fiveaccountserver] GET https://accounts5.roonlabs.com/accounts/3/userinfo?token=ee8e1139-aecd-4de8-bf08-ac56b6bf19c0
04/04 15:01:29 Trace: [broker/accounts] updated token. New expiration is 5/4/2020 3:01:29 PM
04/04 15:01:29 Trace: [push] restarting connection (Unable to read data from the transport connection: interrupted.)
04/04 15:01:29 Trace: [push] retrying connection in 62961ms
04/04 15:01:29 Trace: [broker/accounts] Data updated. AccountStatus=LoggedIn MachineStatus=Licensed UserId=6fbfe46f-171c-4fb5-9a49-74c86cf998fd
04/04 15:01:29 Debug: [easyhttp] [567] POST to https://bits.roonlabs.net/1/q/roon.childprocess.,roon.debug.,roon.broker.,roon.dsp.,roon.client.,roon.sood.?roon_auth_token=ee8e1139-aecd-4de8-bf08-ac56b6bf19c0
04/04 15:01:29 Trace: [fiveaccountserver] GOT {"status":"Success","profiles":[{"id":"52d3a902-e9ad-497e-b360-6cb19625acf9","name":"Peter","photo":"https://sooloos-profileimages.s3.amazonaws.com/five-6fbfe46f-171c-4fb5-9a49-74c86cf998fd--52d3a902-e9ad-497e-b360-6cb19625acf9.jpg","birthdate":"19620000","facebook_auth":"{ \"accesstoken\": \"EAADeu8DcOV8BAANjhs46yaYXE6Xc9rmLoGYNHZCRWgq3EefC6P3bk4xnYO05sFkEuJ4ZCeHNuIpyqDsvDDKZC5YlupuZC88XlWTmZC2ZB2JhRYobQtIE5lLMXh37JzTpzUdiVwk1Rg0AWTeG25aAIrTAYfyDaTpdpTkO1Rp64QIQZDZD\" }","twitter_auth":"{ \"oauth_token\": \"12846222-yTFUmYszuH7H2aUt7VTCHQGBWozpJ6AoWgWy8vVdM\", \"oauth_token_secret\": \"NCUpiAaNztNqli22cB8ELnXkeuJ1XTGMntTplxjw9uAYx\" }"}]}
