Martin Logan Forte for Roon/Tidal multizone system
I’m setting up a Roon Nucleus / Tidal based budget multizone music system at a recently purchased lake house. I’ve seen positive reviews on the Martin Logan Forte integrated amp and it is being heavily discounted by Martin Logan. Unfortunately, the Forte is not listed on the Martin Logan or Roon websites as being Roon tested.
My questions are:
Can I use the Forte in a Roon/Tidal based system via its AirPlay connectivity as long as the other zone amps also use AirPlay?
Can I group the zones like I can do on my home system which is fully Roon compatible?
I think the answer is yes but would like to know for sure before I go down the AirPlay Martin Logan Forte path.
Thank you in advance for you thoughts on the Forte.
If it’s AirPlay then yes it will work doesn’t need to be Roon tested this only means Roons had in to play with and works. AirPlay devices will work without this. If following your other thread you want this to run from a core at this residence then you would need all zones to work over AirPlay to group to group them. Is using ARC you would use Apple home to group them all and play to it from the phone or tablet.
