no wifi connected directly to dac via optical
spdif
i have quite a few 192 recordings and am looking to upsample to 192 however when i check in device set up it says max sample rate pcm 96 kHz and this is all it will upsample to
Hi
Thanks for the reply
It shows this in my mac before connecting to the dac. Whether I use optical or USB the settings don’t change. I have checked the specs for the mac and it supports 192 via optical
Makes no sense!!!
Can you please share a screenshot of your Device Setup Tab for that Chord zone by using these instructions to upload the screenshots to this site?
Also, can you share a screenshot of your Audio Midi Setup when you have the optical output connected to the Core and the optical input is selected on your Chord DAC?
The Audio Midi setup should look something like this, please post a similar picture outlining the supported sample rates:
