Processor: Intel Core i7-8559U CPU @ 2.70GHz 2.71
Storage: HP SSD S700 250GB
Installed RAM: 16.0 GB
Operating System: Windows 10 Pro
Roon Build Version 1.7Build 555
Ethernet / Wifi Mix Various NETGEAR switches
Linn Selekt DSM (Katalst)
BlueSound Node2i x 3
BlueSound PowerNode2i x 2
Hello, no real problem here, rather an operational question I haven’t been been able to figure out in regards to metadata - Because I listen to a lot of shuffled music, I’d like to be able to group certain tracks together - for example, Frank Zappa’s Apostrophe album: Even during a shuffle, a listener would always want to hear those first 4 songs together , as they are sort of a suite - Yes, they are separate songs, but you really wouldn’t listen to them separately …
I see a possible solution occasionally when listening to Classical music, with the ‘part’ tab. Even during a shuffle, those 4 ‘parts’ or songs, would play together… So the question would be how does one group a selection of songs and assign them a part? Or is there some other solution ?
thank you!!
