I got another Antipodes S40 from my dealer. These had their own core of the dealer. Same problem. In 30 percent it only worked by restarting the Antipodes via the webface. Another user has the same problem, but Quobuz instead of Tidal. The same problems also occurred on my dealer’s network. Software versions all new.
Hello Norris, Thank You for Your Information. My antipodes was connected directly to a FRITZ! Box. The dealer has a different box. However, there is a second user who is in contact with you and who has his antipodes connected via a FRITZ! Box. He has the same problem. I checked the settings on the FRITZ! Box. This point is activated.
I’m seeing a lot of DNS errors in the logs. When you set Google or Cloudflare DNS did you do that directly on the router? Once these DNS errors are resolved you’ll likely be up and running.
thanks for your information. after the cloudflare connection was unsuccessful, I set the router back to its starting position. with cloudflare with the factory setting the same problem. What must I do.
