Xfinity Modem/router, connected to both iMac and NAD C658 DAC with Cat 7 ethernet cable.
NAD C658 DAC, connected to router withCat 7 ethernet cable
I have been running Roon for several months. Out of the blue, two days ago I started getting the “Metadata Improver: Halted. Roon needs a software update” message. Both Roon and Catalina are fully updated.
Thank you in advance for your help!
Can you try to reboot your router and then your Core machine again? Is there any change after a network reboot? Normally this error indicates that there is a problem connecting to our servers, so a network reboot could help.
Thank you. I just did so, and continued to have difficulty.
And then it dawned on me: perhaps this is a Comcast issue! I powered up my Verizon cellular hotspot and used it to connect my iMac to the Internet. What do you know? The issue with the Metadata Improver vanished.
I shall give Comcast a call right now. Thanks to everyone who offered their assistance!
